weird Neutral problem
Results 1 to 7 of 7
    Junior Member zoolander's Avatar
    Nov 2010
    24
    I just bought my wife a '02 TW and she loves it already! It's been sitting for a while now because of the weather and apparently it sat a bit with the previous owner.
    It fires right up but even after several minutes of idling, I'll pull in the clutch to put it into gear and as I pull in the clutch, the neutral light will go out and the bike dies. It won't do this all of the time, but a good 3 out of 5 times it will. Is this a mechanical problem where I have to adjust the clutch or is this more an electrical problem?
    Also, when it is in 1st or second gear, it is hard to find neutral sometimes (related/unrelated to the first problem?).
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    Quote Originally Posted by zoolander View Post
    This might help: https://www.tw200forum.com/forums/81247/ShowPost.aspx
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    Senior Member heyduke's Avatar
    Aug 2010
    Idaho
    163
    Tw's have a strange electrical glitch. They will die if the clutch handle vibrates against the clutch safety switch. That may be whats happening with your bike. Perhaps the switch is not making good contact as it transfers from normally open to normally closed.
    try jiggling the clutch handle does it die then also? Does it die when driving on washboard? If so you might try replacing the switch or just disable it although that means the bike starter will engage while in gear.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Things like the clutch actuated ignition cutout switch and the side stand ignition cutout switch are solutions to non existent problems.
    Un fortunately some time in the past, some dweeb of a congressman embarrassed himself by pressing the starter with the bike in gear and the clutch engaged.
    Rather than admitting that this was a learning situation and getting on with life, he resolved to try to make it impossible for anyone to have this valuable learning experience in the future by a law mandating these switches on all bikes. Thereby condemning the rest of us to two more possible electrical glitch problems from wear and vibration.
    Some people were simply not meant to ride, their tiny brains cannot possibly cope with the responsibility of learning from mistakes.
    helonius
    Phelonius
    Junior Member easy3maw's Avatar
    10
    I read years ago in "Thumper Talk" that the TW is known to do this. You may notice that it is somewhat glitchy in getting back into Neutral. I do know that if you have it at idle and forgot to raise the kick stand it will die when you let out the clutch. The safety switch on the kick stand. It is just one of the "DUHS" that come with the TW.
    Nov 2010
    24
    Thanks for the input to all. I'll figure it out with the direction given. First order of business though is getting the carb off for a good cleaning...(see next post )
    Senior Member Woofhound's Avatar
    Federal Way/Cle Elum Wa.
    369
    make sure the kick stand is up before putting it in gear.......
    2009 WR250R
    2005 V-Strom
    1993 Shadow 1100 with Ural sidecar
    2008 H-D Ultra Classic
    2009 Zuma 125
    2004 Zuma 50
    2000 WR400F
  1. Neutral Switch Problem?
    By adaulton in forum Technical Help
    Last Post: 08-09-2015, 07:09 AM
  2. Neutral or 1st at red light ?
    By willinbc in forum General Discussion
    Last Post: 08-10-2012, 07:37 AM
  3. weird bouncy problem :-\
    By Guit4eva in forum Technical Help
    Last Post: 07-22-2012, 05:55 PM
  4. Yet another weird electrical problem
    By TWisty in forum Technical Help
    Last Post: 06-24-2012, 01:49 PM
  5. Weird clutch problem...
    Last Post: 06-15-2012, 11:25 PM
tw200 neutral switch open
