TW200 on a lift/stand?
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By thumper
Thread: TW200 on a lift/stand?
    Junior Member RynnStorm's Avatar
    For lifting the TW200 off the ground for work (say remove both wheels), what do people use? (Is there enough on the bottom for a standard bike lift?)
    Senior Member thumper's Avatar
    Oct 2010
    232
    Quote Originally Posted by Rynn View Post
    I stole this idea from the Broken Veteran (I hope he's still with us)
    I use 2 milk crates and a section of 2x6. I sit one milk crate on the right side of the bike as close as possible.
    I then slide the board under the bike and on top of the milkcrate. I then simply grab (I drilled 2 holes and placed a piece of rope through them to make a handle with a piece of pvc pipe over the rope) then life the bike up level, then take my foot and push the other milk crate under the board. Bike sits perfectly level, has clearance for oil change, service, etc. you can even sit on the boards if they are long enough for a service stool Etc.
    I've got 2 different M/C lifts, but I use this method because its faster and more stable.
    Hope this helps.
    jase13 likes this.
    866
    Good idea igofar. All of the center stands I have are too tall for the TW. And despite it's small size, it's a heavy bike.
    Ephrata, WA
    1,125
    I use an ATV jack. Igofar's trick sounds good too.
    1990 TW200
    Senior Member sorethumb's Avatar
    Bluffton, SC
    663
    I use this, http://www.harborfreight.com/automot...lift-2792.html with a square piece of 1/2" plywood across the arms to create a flat base.
    Custom 1998 TW200 Build Thread Hidden Content | 2003 TW200 | 2009 KLX351
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    I would love a center stand for this bike, for maintance and so it takes up less floor space. Heavy? this bike is superlight, my Honda ST1300 weighs at least 650 lbs. My DL1000 was over 500 lbs.
    866
    You're right, greg. I should be able to man handle the old TW.
    Senior Member mga60tw's Avatar
    Fl
    215
    I use the motorcycle swingarm from harbor freight http://www.harborfreight.com/automot...and-66192.html and you can buy the piece to lift the front tire. Works great!!
    I have a platform lift--roll the bike up, strap down one end or the other, put a bottle, scissors, or floor jack topped with a piece of 2x6 under the skidplate.
    Senior Member FnMag's Avatar
    493
    I lift mine up onto a coca-cola crate. But IGOFAR's idea sounds great.
  1. Lift the height at the back on my Tw 125
    By Elvdaking in forum Technical Help
    Last Post: 05-28-2013, 08:48 PM
  2. Stand or Jack?
    By nfpgasmask in forum Technical Help
    Last Post: 09-25-2012, 09:52 PM
  3. Tdub up on the lift for chain and sprockets.
    By qwerty in forum Technical Help
    Last Post: 08-30-2011, 03:19 PM
  4. TW - What's it stand for?
    By Rohnsman in forum General Discussion
    Last Post: 06-21-2011, 11:14 PM
  5. Cheap hydraulic motorcycle lift
    By dhoenisch in forum General Discussion
    Last Post: 03-07-2011, 08:13 PM
cennnter stand for tw200
lift stands for yamaha tw200
lifts stands yamaha tw200
motorcycle stand tw200
rear lift stand for yamaha tw200
stand
tw200 center stand
tw200 centerstand
tw200 forum lift
tw200 lift
tw200 motorcycle stand
tw200 stand
