How do I get to the battery
Results 1 to 8 of 8
    Junior Member mike m's Avatar
    28
    I think the battery is under the seat, but can't seem to figure out how to get it off.
    Plaease any help.
    Devon, England.
    614
    If you get down on your knees and look up between the tyre and back mudguard you will see 2 bolts that go straight up into the seat base, undo these and the seat will lift up and back to remove.
    Then the battery is easy to access.
    If you search "mule nuts" and seat I think you will find a picture.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,385
    Quote Originally Posted by uktw125 View Post
    ...If you search "mule nuts" and seat I think you will find a picture.
    The pictures of the mule nuts on the old forum seem to be gone.
    Removing the seat: page 3-8 of the Owner's Manual.
    http://www.mediafire.com/?8zubjzjyioj
    jb
    Nov 2010
    Frostbite Falls Ill
    2,719
    You may find it easier to put back the seat and easier access in the future, if you replace those bolts with the same size stainless alan head bolts.
    A short allen wrench will then hold the bolt for you as you blindly grope for the right place.
    This seat mounting system was not one of Yamahas finer designs.
    Phelonius
    Phelonius
    Senior Member rm_hm's Avatar
    1,619
    FL. GA, NC
    2,385
    Quote Originally Posted by Rich View Post
    Still no pictures...
    jb
    Frosty Hollow
    12,912
    FL. GA, NC
    2,385
    Aha! You've found them Admiral.
    Thanks.
    jb
  1. Battery
    By mga60tw in forum Technical Help
    Last Post: 07-24-2016, 03:57 PM
  2. New Battery Help
    By cptrout in forum General Discussion
    Last Post: 12-05-2012, 08:12 AM
  3. New battery
    By trbixler in forum TW200 Classifieds
    Last Post: 03-25-2012, 09:24 AM
  4. Best battery?
    By Matthew Rowland in forum Performance and Customization
    Last Post: 02-06-2012, 10:02 AM
  5. Run w/o battery OK?
    By Rohnsman in forum Technical Help
    Last Post: 01-30-2011, 01:32 PM
how do you replace the batttery in a 2015 yamaha bolt
how to remove battery on a 2016 yamaha tw200
replace battery on tw200 yamaha
tw 200 battery location
tw200 battery access
tw200 battery location
tw200 battery removal
tw200 battery replacement
tw200 battery size replacement
tw200 seat removal
where is the battery on a yamaha tw200
yamaha tw200 battery location
