How to remove ignition? Help....
Results 1 to 9 of 9
    Junior Member ericmu22's Avatar
    6
    Can anyone tell me how to go about removing my ignition switch. I lost my only key and I need to remove the switch so I can take it to the local locksmith so they can make a new one. They told me all I need was the switch and the title but im not sure how to go about removing it. Any help would be appreciated. Thank you.
    Senior Member JarrodWeaver's Avatar
    Austin, Texas
    112
    PM me directly if you would like more details on how to do this.
    "edited by moderator"
    Senior Member stinkycheezmonky's Avatar
    Oct 2010
    Winchester, VA
    109
    Question about that method: do the forks lock without a key? I have a second bike I was going to use as a trail-only bike, and it's be great to not have to drop $100 on an ignition set.
    jvt
    jvt is offline
    Senior Member jvt's Avatar
    Enumclaw,washington
    136
    would you post a photo of this bike?
    our old fourm replys on wiring like this got removed.
    I wonder if the helmet lock will do?
    Junior Member imnxnyr's Avatar
    Oct 2010
    16
    There are 2 hex bolts that hold the ignition/key module in place. they are accessible from the underside of the module and can be reached by turning the forks all the way left and right.
    Some years/markets have switches attached to the triple tree with 2 bolts from the top. Others have 2 bolts from the bottom. Either way, a socket and extension makes short work of removing them.
    Senior Member thumper's Avatar
    Oct 2010
    232
    With all due respect, and without offending anyone, I think this thread would be best answered in a private email, rather than post
    how easy it would be to HOT WIRE a TW200. If ya'll remember a while back, we had a rash of stolen bikes. Lets just be carefull what we
    post out there....you never know who is on the other keyboard.
    Just saying
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    Igofar is right. Thread closed.
    Regards...Wes
  1. How to remove front bearings?
    By Guit4eva in forum Technical Help
    Last Post: 09-08-2012, 07:26 AM
  2. Remove baffel
    By hoofhearted529 in forum General Discussion
    Last Post: 07-25-2012, 08:16 PM
  3. How to Remove Starter Motor
    By Snake2715 in forum Technical Help
    Last Post: 06-15-2012, 02:55 PM
  4. how to remove the clutch
    By Thomas K in forum Technical Help
    Last Post: 01-06-2012, 11:12 PM
  5. Remove TW logo from Tank?
    By Rohnsman in forum General Discussion
    Last Post: 08-10-2010, 12:51 PM
how to remove ignition from yamaha tw200
how to remove the ignition on tw200 yamaha
how to remove the ignition switch on a tw200
how to remove tw200 ignition
how to remove yamaha tw200 ignition switch
remove switch on a tw 200
tw200 has oil bath ignition
tw200 key switch removal
tw200 remove ignition
yamaha tw200 ignition removal
