Seal replacement during chain/sprocket replacement
Results 1 to 10 of 11
Like Tree1Likes
Thread: Seal replacement during chain/sprocket replacement
    Senior Member TWROG's Avatar
    Dec 2014
    Stockbridge GA
    807
    Ive got a new Xring chain and sprockets. While reading up on replaceing them I notice everyone says to replace the seals. How many are there and what are they called specifically?
    #s 23 and 30?
    #3?
    #7? It says its obsolete
    Any others?
    2009 TW200 "Cracker" - His fun ADV bike
    2006 TW200 "Blue" - Her fun ADV bike
    2011 XL1200X "48" - My cool bike
    1977 KZ650 - My vintage sport bike
    Frosty Hollow
    13,082
    The seals they are talking about are located here. Very good idea to inspect them at the very least. After removing my left side cover many times, I personally have never had to change any of these out, but I do inspect them. Eventually any seal will fail, up to you if you want to do it before it actually does.
    The other seal to check and/or replace is the output shaft seal located on the left side cover. I have had to replace this
    seal once.
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    I haven't changed mine yet, but I'm also replacing chain and sprockets in the next couple weeks. Common sense tells me, Yes, those are correct. Don't know why the shift shaft seal is obsolete. That's weird. Did you try looking somewhere else? You don't "need" to replace them unless they leak. #30 won't leak, just let dirt get to bearing if bad. Just check them and clean. Put a little oil on the lip of seal when putting back together. I use grease sometimes.
    Bob
    When in doubt, Gas It..!!!
    Dec 2014
    Stockbridge GA
    807
    Thanks all. This bike lived on the coast with much of it spent on the beach, grit everywhere. Think Ill go ahead and replace them and be done with it. I checked a number of places.........shift shaft seal seems to be obsolete.
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    797
    rockymountainatvmc.com has them. thats where I get most of my parts
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. sold to a new home 11-24-17
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content for sale
    Pleasanton, CA
    5,743
    Quote Originally Posted by Werloc View Post
    Just a minor clarification - the outboard bearing #30 in the stator side cover does have an oil supply via the ouput shaft #11 and will leak if worn or damaged.
    Hikerglenn likes this.
    Dec 2014
    Stockbridge GA
    807
    Quote Originally Posted by vanillagorilla1 View Post
    Quite a bit more expensive than partzilla.................but they do have it so thats what counts. Even paying shipping from each place its cheaper to get only the shift shaft seal from rocky mountain and the rest from partzilla. Thanks all.
    Nov 2013
    Central, NJ
    1,983
    Ok, good to know. I haven't ripped into my bike yet, so I didn't know. Didn't really look at parts pic that close either. Thanks.....
    Bob
    Senior Member Hikerglenn's Avatar
    Jul 2014
    Smoky Mountains
    297
    Ya , Bob oil actually flows through the center of the countershaft and lubes that outboard bearing in the cover, then flows back into the engine, kinda' unique and neat.
    "Right's right -even if nobody's doing it and wrong's wrong -even if everybody's doing it"
    Nov 2013
    Central, NJ
    1,983
    Yeah, that is cool. Never had my hands on a motor that had an outboard type bearing like this. I guess if there wasn't oil supplied to that bearing, it would need to be sealed bearing.
    Bob
  1. Fork oil seal replacement
    By canadainshiver in forum Technical Help
    Last Post: 03-02-2013, 07:55 PM
  2. good replacement chain for use with stock sprocket size
    By grt1982 in forum Technical Help
    Last Post: 07-11-2011, 05:07 PM
  3. Cost for fork seal replacement?
    By Rohnsman in forum Technical Help
    Last Post: 11-16-2010, 01:00 PM
  4. Fork Seal Replacement?'s
    By brownie2 in forum Technical Help
    Last Post: 11-08-2010, 07:08 PM
  5. Chain and sprocket replacement
    Last Post: 09-01-2010, 06:46 AM
how to put out oil seal sprocket from any bike
how to remove countershaft seal tw200
removing counter sprocket on yamaha tw200
removing countershaft seal tw200
replacing tw200 chain and sprocket
yamaha tw200 trans seal part no
