AirBox Intake Hose Problem
Results 1 to 10 of 12
    Senior Member FnMag's Avatar
    493
    Hey guys, New here and have run into a slight snag.
    Part number 18 on this Page doesn't not have part 18 on it. Obviously, it should. However, after fiddling with the hose, I see no possible way that I can even get the hose to reach the carb. I've tugged, twisted and tried my best to even get them to mate up. I just don't see how it is going to fit....
    Any suggestions ? It seem to run okay even with a slight gap between the boot and carb, but I dont want to suck anything bad into it. I don't plan on doing any dirt riding right away, and may not ever.. So, a K&N and removal of the airbox may be in the works anyway.
    Pic for proof of the existence of said TDub :
    After
    Before
    Member underthewheel's Avatar
    30
    use a heat gun two make the tube softer and you shod be abel to make it fit,weth age the tube get stiff and hard two fit and even shrenk,heat is the keys two these prolem.
    fontintown firmarshel,
    tenny
    Junior Member jclovesu's Avatar
    22
    Order a new air box to carb tube. They shrink over time. I had the exact same year as yours and when I replaced the tube, it was about 1/2 inch longer than the one on the bike.
    Tim
    Ephrata, WA
    1,125
    Mike,
    Been there done that. I've heated mine with a hair dryer and heat gun, boiled it in water, and left it out in the sun. It works to heat it up, but after it cools it shrinks again. You need to get a new one. My old one was about 3/4 of an inch shorter than the new one.
    1990 TW200
    493
    Thanks Guys !!! I'll order one today.
    30
    just for record, weth it heated up u installs it in positen on airbox and carberater weth clamp and it doesnt shrenk untel you take it of again next time,you dont just heat it up and two see if it get longer, but if you want two spend the money and wait, buying a new one will work two.i persenally woodent buys a new one unles it had hole in it.
    tenny
    Junior Member jakemistake's Avatar
    Way Out West
    16
    I just bought a 1991 with the same problem. Had a new top hose off a 90's Chevrolet pickup (new). Cut it to size, with the right angle, fit perfect onto the carb and into the airbox. The redneck way to do it, but it worked!
    When in doubt, Gas it!
    Member adavis's Avatar
    Pullman, WA
    77
    I got my replacement airbox off ebay the other day and the hose on it was a miniature version of the one I have. I was wondering if I had gotten the wrong part, but after seeing this thread I feel relieved. I can't believe those things shrink like that!! The one I just got is off an '87 and it is literally 2/3 the size of the one off my '06.
    Junior Member leborico's Avatar
    Jan 2011
    Montreal
    6
    Hi guys,
    same problem here,
    Where can I find those boots ? can't find them anywhere on the internet :S
    493
    Quote Originally Posted by leborico View Post
    Hi guys,
    same problem here,
    I got mine from either Motorcycle Superstore or Rocky Mountain Atv.
  1. Old airbox boot.. new airbox boot.. still too short
    By silverhead in forum Technical Help
    Last Post: 05-10-2013, 12:36 AM
  2. fuel hose routing
    By bikerjosh in forum Technical Help
    Last Post: 02-18-2013, 04:24 PM
  3. WTB: Intake manifold / Intake boot for '87 - '00
    By len in forum TW200 Classifieds
    Last Post: 08-08-2012, 05:04 PM
  4. fuel hose sizing
    Last Post: 08-31-2011, 08:35 PM
  5. Weird carb hose
    By 805gregg in forum Performance and Customization
    Last Post: 11-20-2010, 08:41 PM
how to keep tw200 intake hose on
tw200 carb fit and airbox
tw200 intake boot
tw200 yamaha replace air intake hose
yamaha tw200 new carb intake size
