Check Your Kickstand!!!
Results 1 to 7 of 7
    Senior Member Kev250R's Avatar
    Orange, So.Cal.
    284
    Hey all, I just wanted to share something a TW-riding friend and I noticed about our TW's. On our two bikes (which are ridden probably 80% off-road) both seem to suffer from from loose kickstand syndrome. Basically the large nut (17mm?) which holds the kickstand in-place seems to work it's way loose. My friend noticed that his was loose on his TW with ~1,200 miles on it, then noticed mine (with 6,500 miles on it) was also quite loose (in fact it seemed it was close to falling-out!) So check that bolt guys (and maybe add a drop of blue Loctite if you're so inclined). Just a word to the wise!!!
    Kevin
    '04 TW - Ricochet skid plate, IMS pegs, Odyssey battery, Seat Concepts seat, wide front tire. Geared low N' Slow Hidden Content
    Honda Grom
    KTM 990 Adventure
    Senior Member bbagwell's Avatar
    Salem, Oregon
    421
    Thanks for the tip . Mine was loose as well. (3800 miles)
    Bryan Bagwell
    1995 Yamaha TW200
    1983 Toyota PU
    2002 Suzuki Grand Vitara
    Senior Member Boret's Avatar
    Aug 2010
    Northern VA
    404
    Thanks for the heads up!
    Lower Rio Grande, New Mexico
    1,702
    Just a mild hijack of thread. Its a good idea to go over the entire beast about once per month to look for bolts, nuts, and screws that are loose or missing. In the first week I had my bike, I tried to loose my license bracket, sometime in the first year my helmet lock went completely missing -- it was then that I invested in some loctite and began my regular preventive tightening/checking. Nothing has gone astray in the last 5,000 miles. Tom
    Central New Mexico
    Senior Member biglefti's Avatar
    Oct 2010
    SCW, AZ
    527
    Mine was tight, but I only have 179836 miles on her.
    OK, 5000 <G>
    Senior Member Grant's Avatar
    Durbanville, Cape Town, South Africa.
    118
    Mine was really loose!! So Many thanks!
    Mar 2011
    Gobles, michigan
    1,826
    What nut ????????????????????? OMM.I'll check ours tomorrow.
  1. Broken kickstand stud
    By kestrel4 in forum Technical Help
    Last Post: 06-13-2012, 11:30 AM
  2. kickstand extreme lean
    By misterpepper in forum Technical Help
    Last Post: 10-20-2011, 06:37 PM
  3. ahhh my kickstand broke off
    By GlassAnkles in forum Technical Help
    Last Post: 09-19-2011, 11:40 AM
  4. Kickstand rattles
    By n2o2diver in forum Technical Help
    Last Post: 06-15-2011, 10:47 PM
  5. amazing new kickstand alternative
    By layne in forum General Discussion
    Last Post: 04-04-2011, 05:37 PM
motorcycle kickstand mount broke off tw 200
tw200 kickstand
