2014 Valve Clearance
Results 1 to 9 of 9
Like Tree10Likes
  • 3 Post By mhomadness
  • 1 Post By Purple
  • 1 Post By Motoad
  • 2 Post By elime
  • 1 Post By Motoad
  • 2 Post By Motoad
Thread: 2014 Valve Clearance
    Senior Member Motoad's Avatar
    Oct 2014
    Creston, BC
    547
    Seems my owner's manual failed to include that. Time for the 1000 km. service. Can anyone provide?
    As always, appreciated,
    Toad
    Mar 2012
    Boonville, No.-Calif.
    1,357
    0.002-0.004 intake / 0.004-0.006 exhaust. 0.05-0.09mm in / 0.11-0.15mm ex
    Better check the service manual first, Don't take my word for these spec's! Try this link:
    https://tw200forum.com/forum/technica...r-manuals.html
    SanDue, TWilight and admiral like this.
    Mar 2015
    Ynys Môn
    4,571
    Weird - your right - the manual doesn't show it. You can take apart the brakes and steering head - but valves ? - Yamaha dealer
    Try this for the pre-2000 model - don't suppose it's changed much - page 38
    https://drive.google.com/file/d/0B0c...ew?usp=sharing
    TWilight likes this.
    - Hidden Content
    Oct 2014
    Creston, BC
    547
    Admiral confirmed the settings. Thx a bunch, guys.
    6,976
    On the older models if you pulled off one of the side covers, the right one I think, emission information was there and part of that is the valve adjustments.
    admiral and Mel like this.
    Oct 2014
    Creston, BC
    547
    Couple of questions. Did the first oil change and found a pretty good buildup of filings on the filter. Is this normal?
    And looking at the valve covers I can see I can remove them without taking everything apart. And hopefully do the valve adjustment. Anybody done this?
    freedom likes this.
    Mar 2015
    Ynys Môn
    4,571
    Quote Originally Posted by Motoad View Post
    Yes and yes.
    Don't worry about the metal filings in the filter - perfectly normal for the first 1000 miles - (although if you find as much next time, I'd be concerned). Just change the oil and enjoy the ride ......
    - Hidden Content
    Senior Member Hikerglenn's Avatar
    Jul 2014
    Smoky Mountains
    297
    I remove my fuel tank and carb.when i do the valves. Takes a while longer removing everything, but waaay more clearance for my big mitts to get in there.
    "Right's right -even if nobody's doing it and wrong's wrong -even if everybody's doing it"
    Oct 2014
    Creston, BC
    547
    Completed my service. Found the spk plug and valve settings on a sticker on the chain side swing arm. Removed the seat and tank as it was easy peasy. The chain had stretched a good amount. Lots of play. Moving the adjusting cams one notch almost seemed to tighten it too far. But after a ride it seems just right.
    plumbstraight and Dryden-Tdub like this.
  1. Valve clearance
    By fielding in forum Technical Help
    Last Post: 07-20-2015, 05:51 PM
  2. Valve clearance
    Last Post: 07-23-2012, 12:17 PM
  3. Valve clearance question - HELP!!!
    By kj7687 in forum Technical Help
    Last Post: 03-30-2011, 02:17 PM
  4. Adjusting the Valve Clearance
    By vuldub in forum Technical Write-Ups
    Last Post: 09-01-2010, 07:45 AM
  5. Valve clearance
    By shady145 in forum Technical Help
    Last Post: 08-26-2010, 12:29 PM
2015 valva clerance
