Carb cleaning 101
Results 1 to 7 of 7
Like Tree11Likes
  • 4 Post By goldenhtr
  • 1 Post By rbm
  • 2 Post By Hikerglenn
  • 1 Post By jbfla
  • 1 Post By goldenhtr
  • 1 Post By plumbstraight
Thread: Carb cleaning 101
    Stanwood,Wa
    1,880
    Carb cleaning 101
    Well my son dropped off his bike(2006)TW. Would not idle without the choke on. Did the lazy mans carb fix and it's running great again. Pilot jet blocked. FWIW no one has ever been in this carb and I found no main nozzle as in this pic. Is this going to be a problem? Just took the bike on a 10mi road test and it's running great.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Unless it was stuck in the carb, I don't think mine has a "main nozzle" either... Seems to run just fine with a 130 in there.
    TWilight likes this.
    Senior Member Hikerglenn's Avatar
    Jul 2014
    Smoky Mountains
    297
    They quite often stay stuck in the carb when you pull out the emulsifier tube. Just look through the bore of the carb and you will see it sticking up just a tad. I use a plastic tool to push it out. If it wasn't in there, the needle would rattle around horribly and it would never be able to even idle, would just be sucking gas through the main jet at all times. When re-installing it, just make sure the countersunk side is up, the beveled edge down, toward the emulsifier tube.
    jbfla and TWilight like this.
    "Right's right -even if nobody's doing it and wrong's wrong -even if everybody's doing it"
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Quote Originally Posted by Hikerglenn View Post
    + 1
    You would know if the main nozzle (needle jet) was not in place. It wouldn't run fine.
    jb
    Stanwood,Wa
    1,880
    Well maybe it was just stuck up in there. Like I said it was the lazy mans carb cleaning. Just rotated the carb. 90* and removed the jets and cleaned them. Going to ride it into town to my grandsons baseball game then back to my sons house.
    Gen:27:3
    -Ronald Reagan
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,718
    I see the cleaning wires in the kit. You can pick up a set of torch cleaners which come in a set just like that at any welding shop/store. I just did a cleaning on mine and they are small enough to do the job. Just a heads up.
    Stanwood,Wa
    1,880
    I may have to pick one up. That pilot jet hole is tiny tiny tiny.
    Gen:27:3
    -Ronald Reagan
  1. Lazy Man's Carb Cleaning Questions
    By Avi Kwame in forum Technical Help
    Last Post: 04-09-2013, 07:06 PM
  2. carb cleaning
    By phelonius in forum Technical Help
    Last Post: 01-29-2012, 12:24 PM
  3. Carb cleaning for dummies
    By Whippet in forum Technical Help
    Last Post: 04-07-2011, 09:18 PM
  4. Lazy Man's Teikei (TK) Carb Cleaning
    By jbfla in forum Technical Write-Ups
    Last Post: 12-08-2010, 10:48 PM
  5. Carb cleaning for dummies
    Last Post: 10-11-2010, 04:53 PM
how to clean carb
