TW will not start after changing the front sprocket
Results 1 to 10 of 13
Like Tree13Likes
Thread: TW will not start after changing the front sprocket
    Junior Member Tansoo's Avatar
    May 2015
    South Florida
    10
    I changed my sprockets (rear and front ) and after putting all the TW together, I can not start the TW. I just hear noise from the battery. I was very careful not to touch any electrical when reassembling the front case. Any ideas?
    Thanks
    Member KeysRyder's Avatar
    May 2015
    Florida Keys
    43
    All I would say is that you messed up a wire coming off the stator. Will it crank at all? Or does it not fire while cranking over?
    May 2015
    South Florida
    10
    no, it does not crank up, just a buzzing noise is coming for the battery area. might have to open it all up again.
    thanks for your advise.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    I'd take a look just to make sure.
    May 2015
    South Florida
    10
    i read some about the torque applied to the bolts when putter the strator back can make the bike not start? any truth to that? Sound impossible
    Sep 2012
    Northwestern Oregon
    1,092
    Could be a pinched/damaged wire when you put the cover back on.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Now you have totally buggered the bike. Just send it to me and I will dispose of it for you for free.
    Phelonius
    May 2015
    South Florida
    10
    Now that is good advise. the battery had no water in it so let me charge it before considering your kind offer!!!
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    I bet you pinched a wire in there and is grounding out. A few here had similar issues doing the same thing. Remove cover and inspect well. Anyone wanna place a bet on what color wire?.....
    Bob
    When in doubt, Gas It..!!!
    Senior Member 87bags's Avatar
    Sep 2014
    Northern KY
    201
    Definitely start with the battery. If it is low on acid it's not going to work or will not work very well if it is. Rule the battery out first then look into the next logical possibility.
    TWilight likes this.
    Ride Safe.......You're the BUMPER!Hidden Content
    2003 Yamaha TW200
    2008 Kawasaki KLR650
    2005 BMW K1200S
    2009 Honda 420 Rancher 4x4
    Hill Billy Bags
  1. Changing front sprocket
    By Yan in forum Technical Help
    Last Post: 08-18-2014, 08:49 PM
  2. Changed the counter sprocket and now the bike won't start
    By rurlndum in forum Technical Help
    Last Post: 06-22-2013, 07:05 PM
  3. Front sprocket
    Last Post: 07-20-2012, 06:54 AM
  4. Changing sprocket and chain
    By critter52 in forum Technical Help
    Last Post: 03-02-2012, 05:08 PM
  5. Changing front sprocket
    By Omega Man in forum Performance and Customization
    Last Post: 02-09-2012, 09:36 PM
