15/54 Sprockets, What Length Chain?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree11Likes
Thread: 15/54 Sprockets, What Length Chain?
    May 2014
    Yooper, MI
    1,510
    As the title suggests I'll be installing 15 front, 54 rear sprockets. Going with a D.I.D. 428 Pro-Street VX Series X-Ring Motorcycle Chain, D.I.D. 428 Pro-Street VX Series X-Ring Motorcycle Chain - BikeBandit.com . Stock is 122 and I have about an inch and a quarter space between the front of the wheel and the swing arm.
    Should I get the 126 or the 122?
    Member KeysRyder's Avatar
    May 2015
    Florida Keys
    43
    I would get 126 that would be about right
    Senior Member oilhed's Avatar
    Jun 2014
    Central CT
    486
    May I ask why? Going up on both ends negates the change.
    Mark Flanagan
    aka OILHED
    2014 Yamaha TW200 &
    2001 BMW R1150GS
    Hailey, ID
    3,346
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    May 2014
    Yooper, MI
    1,510
    oilhed I have new (used) rear wheel coming and I'm putting a Duro Power Grip on that. I'm going to put the 54 tooth on that and with the 15 in front of it it should be pretty close to stock, which I think is just fine for trail riding, stump jumping and such. I'm going to leave the the 50 on the stock rim/tire and with the 15 in front of that it should be adequate for road use. Then I can just switch back and forth and not wear out my Duro on the roads.
    TWilight and Dryden-Tdub like this.
    Jun 2014
    Central CT
    486
    Quote Originally Posted by Devils Advocate View Post
    Great idea. Hows that work with the drum brake, do you have two setups or just move the pads from one drum to the other?
    Mark Flanagan
    aka OILHED
    2014 Yamaha TW200 &
    2001 BMW R1150GS
    May 2014
    Yooper, MI
    1,510
    Wheel is coming with it's own brake shoe plate. I'll assess those shoes and drum when I actually have it in hand. Should be here Thursday.
    Germany, Werdau
    1,014
    I don't understand, why do you want to use that gearing.
    Stock is 14/50 -> 3,571
    15/54 -> 3,600
    This is 0,8% longer as stock.
    -->> There no sense to change to 15/54
    May 2014
    Yooper, MI
    1,510
    macbig2k1
    Read my post, #5 above, two above yours.
    Stanwood,Wa
    1,880
    DA, I kinda see Mac's point. Everyone i've seen put on a duro seems to be going 14/55 because of the tires weight and size to get closer to stock gearing and maybe a little better dirt performance. Been watching the duro threads for a long time. I f I had an extra wheel like you I would be doing the same thing. One for a duro and one stock, but my duro would be setup for more dirt/trail riding 14/55 or 60. Good luck on the mounting and let us know how it goes. On the chain, I would get a 130 and cut it down so you can have the max amount of room for that duro and still use it for your stock setup.
    Dryden-Tdub and TopPredator like this.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
  1. Replies: 5
    Last Post: 01-01-2016, 12:15 PM
  2. Chain length question
    By wyelkhunter73 in forum Technical Help
    Last Post: 07-07-2014, 10:48 AM
  3. Sprocket/chain length calculator
    By goldenhtr in forum Technical Write-Ups
    Last Post: 04-20-2014, 09:47 AM
  4. Chain Length
    By Rainman in forum Technical Help
    Last Post: 11-30-2012, 09:36 AM
  5. Chain length?
    By Roninboise in forum Technical Help
    Last Post: 02-09-2012, 08:26 PM
2001 yamaha tw200 chain length
what size motorcycle chain do i need 15 54 sprockets
