Which direction is the oil element supposed to go?
Results 1 to 5 of 5
Like Tree14Likes
  • 6 Post By TW-Brian
  • 3 Post By Eric
  • 5 Post By Fred
Thread: Which direction is the oil element supposed to go?
    Member Eric's Avatar
    Jun 2014
    Helena, MT
    84
    Which direction is the oil strainer supposed to go?
    Just finished my first oil change and made a cardinal mistake. After taking the drain plug, compression spring and oil strainer out I did NOT pay attention to the screen direction. After putting it back together and changing the oil (black and full of filings at 137 miles) I realized I may have inserted it incorrectly. Using the diagram on page 3-12 of the service manual, I put the oil strainer how it is in the photo, where the screen is inserted into the compression spring and the assembly inserted. Should the strainer be the opposite, where the ring of the strainer is against the compression spring and the basket of the strainer protrudes into the engine? That seems logical as it would put the strainer inside the engine rather than just inside the spring. If I did it backwards, should I re-do the change or will it be OK until the next change?
    Sorry for the newbie question.
    Thanks
    Pleasanton, CA
    5,721
    Hi Eric,
    Here is the way it should go back together.
    Brian
    scotti158, evan, Fred and 3 others like this.
    Jun 2014
    Helena, MT
    84
    I got lucky then as that is how I did it. Thanks a lot for taking the time to take the photo. Time to ride.
    TW-Brian, SanDue and admiral like this.
    18,719
    TW-Brian to the rescue again.
    Took him 13 minutes this time though, he must have taken time out for lunch.
    SanDue, TW-Brian, kince and 2 others like this.
    Mar 2015
    Ynys Môn
    4,571
    No-body's perfect ......
    - Hidden Content
  1. Replies: 6
    Last Post: 05-11-2015, 12:12 PM
  2. Please God tell me there is supposed to be............
    By Dryden-Tdub in forum Technical Help
    Last Post: 05-03-2015, 06:06 AM
  3. I don't see a direction arrow on the S-244
    By ZDR1 in forum General Discussion
    Last Post: 04-21-2014, 07:46 AM
  4. New to the TW looking for direction
    By duckmutts in forum General Discussion
    Last Post: 03-27-2012, 07:43 PM
  5. air filter element
    By sea bass in forum Technical Help
    Last Post: 08-25-2011, 01:52 PM
yamaha tw200 oil strainer direction
