1990 TW 200 Carb Vent lines?
Results 1 to 6 of 6
    Junior Member sasnydley's Avatar
    24
    I am in the slow process of redoing this bike. I took carb off a while back to do some Major cleaning (Bike had been sitting til tank rotted) bike did run prior to me taking it apart- Now putting back together. There is some sort of Vent port on each side of carb. What or where do these hook to or go? Can't find any good pics if older carbs with lines hooked up. Thanks! I have been waiting for a friend to braze tank.... Now if I can get it up and running again I may just order oversize tank off Ebay. First I have to go put a clutch in my (my sons) 97 Kawi Lakota
    Senior Member jonjon122's Avatar
    Jan 2011
    Tombstone Arizona
    102
    https://tw200forum.com/index.php?/top...h__1#entry6710
    i know your not cleaning carbs but maby this post has a pic of what your speaking of?
    -Respect the person who has seen the dark side of motorcycling and lived.
    -Winter is Nature's way of telling you to polish.
    -A good rider has balance, judgment, and good timing. So does a good lover.
    -Everyone crashes. Some get back on. Some don't. Some can't.
    -Only a Biker knows why a dog sticks his head out of a car window.
    -'Oh S$$t!' is usually the moment when your plan parts ways with reality
    -Well-trained reflexes are quicker than luck.
    -Don't lead the pack if you don't know where you're going.
    -What do you call a cyclist who doesn't wear a helmet? An organ donor
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Quote Originally Posted by jonjon View Post
    That's a pic of the newer Teikei carb.
    The upper hose is an air vent. The hose from the bottom is for the bowl drain and overflow.
    The carb will still work without the hoses in place. Don't know if that's true on the pre 2001 carbs.
    jb
    24
    Quote Originally Posted by jbfla View Post
    jb
    My carb is different than that. I had found that writeup doing searches. My vents are the exact same height but on opposite sides of carb. I am going to get new spark plug today and see what happens with Make shift tank LOL.
    Junior Member easy3maw's Avatar
    10
    No pics to post. Mine is a 90's mod. A vent tube on the back side (pointing at Battery box/vent box) has a clear long tube that runs down beside the battery vent tube. Turned mine into the shop. being old I hope they can clean it up good.
    24
    Quote Originally Posted by jef-tex View Post
    I actually started mine yesterday! Still have no tank... Used a funnel. I may just Tthe 2 vent together. Didn't seem to matter.
  1. TW died on water crossing - Carb Vent solution offered
    By vuldub in forum Technical Help
    Last Post: 07-08-2019, 04:02 PM
  2. 1990 carb Question
    By Gene-st1300 in forum Technical Help
    Last Post: 06-14-2012, 12:44 PM
  3. photo of brake pad wear braided lines
    By dubstep in forum Technical Help
    Last Post: 04-27-2012, 07:53 AM
  4. Stainless steel brake lines?
    By Xracer in forum Performance and Customization
    Last Post: 01-11-2012, 11:53 PM
  5. PA 1990 TW
    By collinbrackin in forum TW200 Classifieds
    Last Post: 09-26-2011, 04:29 PM
1990 tw200 carburater
1990 yamaha tw200 carburetor
1999 tw200 carb hoses
how to take off carb on 1990 tw
tank vent
tw200 air hose location
tw200 carb vent modification water crossings
tw200 carburetor adjustment vent
tw200 forum 1990 carb
yamaha tw 200 carberator replacement line
yamaha tw200 1990 carb diaphrams
yamaha tw200 carburetor vent hose
