12 volt terminal box
Results 1 to 9 of 9
Like Tree3Likes
  • 2 Post By littletommy
  • 1 Post By mrlmd
Thread: 12 volt terminal box
    Member Aspenmeadow's Avatar
    Mar 2015
    Chiloquin, or
    41
    I have added a Battery Tender quick disconnect charger connection to my battery terminals, which pretty much takes up all available space. Now. I want to add a USB charger for my iPhone and cigarette lighter outlet for my TOMTOM plug in, and I am looking for suggestions on where to tap into a good 12 volt source.
    Spokane, Washington
    17,289
    Why not the Battery tender lead you just installed?
    Purple and Dryden-Tdub like this.
    1st John 1:9
    John 3:16
    John 3:17
    Mar 2015
    Chiloquin, or
    41
    Thanks, I never thought of that!
    Mar 2015
    Ynys Môn
    4,571
    Best place to do it is directly from the battery - so as above - simply use the tender lead .............
    - Hidden Content
    18,719
    It is possible that adding a USB charger whose transformer is always on may have a parasitic current draw that discharges your battery over time. I unknowingly had this problem but fortunately I had a kick-starter.
    Hailey, ID
    3,341
    Yeah, I use my BT lead to power the GPS via a cig lighter socket when it's not being used for charging which I rarely do in the riding season. I tucked it under the right side cover, so I do have to remove that to swap leads, but since it a seasonal thing it's not a problem.
    Fred has a good point....better be sure it doesn't draw when idle, or put a switch in.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Rhodetrip's Avatar
    Aug 2010
    Out wandering around
    1,930
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "When Piggies Fly" ...Me & Mrs Trip Cross the Pond
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Latest Spotwalla: Hidden Content
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Go to the electrical department in a hardware store and buy a "buss" as is used in breaker panel box's. These have holes in them and 'set screws' that will compress and hold tight any wires that are inserted into the holes. You will need to connect these to the battery positive/negative terminals. In my opinion, the task is an easy one, even for beginners. With this set-up you can connect a few more wires 'directly' to the battery.
    Do yourself a favor. Should you move in this direction, clearly label where the wire goes. Tracing wires down that are not on a schematic will be a pain in YOUR ass. Gerry
    Take care my Friend.........
    Senior Member mrlmd's Avatar
    1,153
    Don't forget you really should have a fuse in the positive lead, as close to the battery as possible.
    Gerry likes this.
  1. 12 volt outlet
    By pbfirefighter22 in forum Performance and Customization
    Last Post: 10-09-2012, 09:17 AM
  2. Battery - which terminal should be on which side?
    By jimmytanko in forum Technical Help
    Last Post: 10-04-2012, 03:04 PM
  3. Anyone using the cheap 5-Function Volt Meter?
    By MrDNA in forum Technical Help
    Last Post: 10-18-2011, 10:27 AM
  4. sparks from battery terminal when starting!!!
    By misterpepper in forum Technical Help
    Last Post: 10-12-2010, 02:32 PM
  5. Installing 12 Volt Relays
    By Petrus in forum Technical Help
    Last Post: 10-07-2010, 10:09 AM
Tags for this Thread
