Sprocket shaft swap
Results 1 to 10 of 13
    Senior Member flyhunter3825's Avatar
    Nov 2012
    DePere, Wisconsin
    296
    Sprocket shaft swap
    I havent found a definative answer, so here goes... ik i gotta swap out the side cover, flywheel, etc, but other than that, can i simply take the TWs sprocket shaft and swap it into a ttr225 motor? Why or why not? Thanks.
    May 2014
    Yooper, MI
    1,510
    Pleasanton, CA
    5,720
    If you want to utilize the 6-speed transmission of the TTR225, the TW output shaft will need to be modified.
    If you didn't want modify the output shaft, then you could just swap an entire 5-speed TW transmission into the TTR225 engine.
    With either of the above options, there is also a bearing in the left side TTR crankcase that needs to be changed to fit the TW output shaft.
    Really pretty simple (but still involves a good bit of work with disassembling and reassembling things).
    Nov 2012
    DePere, Wisconsin
    296
    Basically i just wanna put the tw shaft in the ttr. What needs to be modified on the tw shaft?
    Nov 2012
    DePere, Wisconsin
    296
    Pleasanton, CA
    5,720
    Quote Originally Posted by flyhunter3825 View Post
    Sorry Fly, it is not quite that simple.
    The picture below shows a stock TW output shaft on top. A modified TW output shaft is in the middle showing an additional circlip groove and spacer ring added. A stock TTR225 output shaft is shown on the bottom.
    Nov 2012
    DePere, Wisconsin
    296
    So thats it? Just a circlip groove? Ive got a lathe at work that can do that no prob.
    Pleasanton, CA
    5,720
    I say go for it Fly!
    (p.s. I am not machinist, but be advised that this shaft is hardened and I have been told this groove cannot be cut and must be ground, but what do I know !)
    Nov 2012
    DePere, Wisconsin
    296
    Lol, i prolly will. So just to clarify, the only thing preventing it from being a direct swap is the groove? Ive got a ttr225 that, if this works, will be a ttr200. The ttr needs a complete tear down anyway, might as well make it useful.
    Pleasanton, CA
    5,720
    Just to clarify, you will need to add the groove, fabricate and add the spacer ring, and swap the bearing in the left side crankcase.
  1. Stripped shaft! How do I fix it?
    By PalmStateCrawler in forum General Discussion
    Last Post: 04-25-2012, 12:31 AM
  2. Counter-shaft Sprocket Coverectomy
    By Mad Mac in forum Performance and Customization
    Last Post: 02-06-2012, 10:23 AM
  3. TTR225 engine in a TW200, extended front sprocket shaft?
    By Skullhag in forum Performance and Customization
    Last Post: 05-01-2011, 06:27 PM
  4. cam chain sprocket on the crank shaft
    By christddel in forum Performance and Customization
    Last Post: 02-02-2011, 12:05 PM
