V Star shock - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
Like Tree34Likes
Thread: V Star shock
  1. #11
    Senior Member TWROG's Avatar
    Dec 2014
    Stockbridge GA
    807
    Our 2 shocks are not exactly the same. The difference I see is your preload adjuster looks like most shocks, at the bottom with ramps and notches you can see. If you look at the ebay ad pic, my shock has the preload adjuster inside the metal band with holes in it, you cant see the ramps and notches.
    Now obviously that has no impact on if it can be installed upside down or not..........just that they are different.
    Ken likes this.
    2009 TW200 "Cracker" - His fun ADV bike
    2006 TW200 "Blue" - Her fun ADV bike
    2011 XL1200X "48" - My cool bike
    1977 KZ650 - My vintage sport bike
  2. #12
    Dec 2014
    Stockbridge GA
    807
    Ok on to the kickstand. At first I was researching a shorter replacement but if I did find one it would be stab in the dark and Im sure Id have to do some mods. So, decided to cut mine down. First time I cut about an inch section out of it. Had some thread all to put in to act as a temporary support. Not even close. Cut another inch and 3/4, perfect! The foot now sits flat on the floor and the bike is properly leaned. Going to take it to my shop where I have grinders to prep the weld areas and of course a welder to weld it back together. Im going to stop at the hardware store to see if I can find something to put inside the tube (kickstand is hollow) to give it more strength so its not completely reliant on my questionable welding skills
    TWilight, not sure how you got away with not shortening the kickstand. I had to take 2 3/4 inches off mine, probably closer to 3" taking the space my 3 cuts with a hack saw made.
    Ken likes this.
  3. #13
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    "If you want my body, pay shipping and send me a surprize (you be the judge)."
    Quote Originally Posted by badcat View Post
    was i the only person who giggled when they read this?
    am i far too juvenile for this board?
    oops.
    I'd say you were right on the money badcat. It has always been my thought that a misunderstanding like that with a Harley rider could get you killed. Being the well rounded fellow he must be, TWROG just let it slide. I was however really looking forward to that 'surprize'. Gerry
    badcat likes this.
    Take care my Friend.........
  5. #14
    Senior Member badcat's Avatar
    Jan 2015
    Auckland New Zealand
    357
    Quote Originally Posted by TWilight View Post
    Yes, only you. No one in North America will admit what you did...so only a Kiwi would think like that.
    the overuse of the word "bouncy" also made me question my adulthood.
    GTG likes this.
  6. #15
    Dec 2014
    Stockbridge GA
    807
    Ok all done. Didnt go to the hardware store, had some 3/4" thread all from a past project laying around. It was real close. So I just tapped the inside of each kickstand tube, put the thread all in one end.
    And screwed on the other end. Lined it up and it left a little gap, perfect for welding.
    I am NOT going to show my lack of welding skills So here it is after grinding and painting.
    I used an angle finder app on my phone, it leans 2 degrees less than my 09..........close enough. Dont know if the pics will stay side by side but here is before and after.
    littletommy, GTG, badcat and 5 others like this.
  7. #16
    Mar 2015
    Ynys Môn
    4,496
    Nice job TWROG ......
    littletommy, JerseyJeeper and Ken like this.
    - Hidden Content
  8. #17
    Member yahodahan's Avatar
    Aug 2016
    Athens, OH
    84
    Quote Originally Posted by TWROG View Post
    That did it! No more bouncy. I set the preload to midway now the only way the tire will rub is flying off that jump the opposite way, rubs on landing [...]
    Sorry to necro, but I wanted to say THANK YOU SO MUCH, I would never have thought to try this. My vstar shock was an absolute pogo-stick, terrible. Flipped it around just now (did it without removing swingarm, lots of shoving and swearing, but it works!), and SO much better now!
    If any mods/admins see this, do you think this flippy-info could be stickied or somesuch? I'd say it's worth it. Or maybe it's just super obvious to everyone else
    Ken likes this.
  9. #18
    Junior Member Pamacheyon's Avatar
    May 2017
    USA
    THANK YOU to all on this thread - my shock was mounted upside down by the shop and flipping it fixed the bounce/bottoming out issue. Amazingly easy! I have a 2013 TW200 and and 5'1" and now it fits me perfectly. Thanks again.
  10. #19
    Nov 2010
    Frostbite Falls Ill
    2,719
    Giggling at other peoples difficulties is a requirement for a biker.
    littletommy and admiral like this.
    Phelonius
  11. #20
    Junior Member gifty74's Avatar
    Apr 2019
    21
    So what is the verdict on the V Star shock, rod side down? Opposite of the stock shock, correct?
  1. The TW Is A Movie Star!!
    By BRug14468 in forum General Discussion
    Last Post: 05-06-2015, 03:01 PM
  2. Blaster shock
    By small's in forum TW200 Classifieds
    Last Post: 03-30-2014, 08:44 PM
  3. Star Bolt
    By OSOK in forum Off-Topic
    Last Post: 11-20-2013, 06:08 AM
  4. Shock Help!!!
    By WhiteLightin in forum Performance and Customization
    Last Post: 03-06-2013, 12:35 PM
  5. V star shocks
    By solarae in forum Performance and Customization
    Last Post: 10-14-2012, 05:19 PM
installing a vstar rear shock on tw-200
lowering tw-200 with vstar 1100 rear shock
shock for v star
what end of rear shock vstar1100 is up when mounted on tw-200
