Putting a new float boal gasket on....
Results 1 to 5 of 5
    Junior Member Kosovo101's Avatar
    Apr 2013
    Scipio Center ny
    6
    My float bowl is covered in burnt gas at the seam and it only runs with full choke. Im guessing i have an air leak at the float bowl. I wanna know what i need to do to take the throttle cables off before i just start blindly messing with it. Its a 2012
    Spokane, Washington
    17,289
    You might try using a JIS screwdriver and very gently try to tighten up the screws first. Run a strong dose of Lucus Deep System Fuel Cleaner/or Seafoam in the tank (3 or 4oz) and drive it. Personally, I use the Lucus for bad problems and the Seafoam for maintenance from time to time. It could be a bad gasket though. I would try tightening it first.
    1st John 1:9
    John 3:16
    John 3:17
    18,719
    Tighten, but not too much! To remove the float bowl we usually remove the throttle cables but it is possible to do rotate the carb enough to access the float bowl screws with carb still on bike and cables attached. However I would be tempted to remove and inspect/ clean the carb and thus know it is in good shape before reassembly. this will also help ensure the float bowl gasket is installed correctly. The service manual describes the entire process including cable removal and re-installation.
    I usually deviate from the recommended cable procedure and leave cables attached to the plate on the carb and simply remove plate and return spring leaving cable adjustment un-altered. However reinstallation requires pulling the return spring clockwise with a thin piece of wire or string until spring engages it's detent. This requires working blind since you cannot see spring, takes a bit of finesse and/or grumbling the first time.
    If you do not have the Service Manual and Supplement it is available online, downloadable for free. You should be able to use the search feature there to find a link for the free-bees.
    "Burnt Gasoline" may hopefully not be the most accurate term but irregardless it is good that you want to address and solve the problem. Good Luck!
    Apr 2013
    Scipio Center ny
    6
    Lol yeah burnt gasoline doesnt sound right for sure, but with it running so hot from high idle its turned whatever gas comes out the carb bowl to burn red/brown onto it!
    18,719
    I have a pet phrase ..." I hear what you mean, not what you say" so perfectly accurate terminology isn't always that important. I was first thinking "varnish" but from your description "burnt gas" sounds equally good. After all the leaking fuel's volatiles evaporate away residual less volatile opponents attract dirt forming the highly technical term " Grunge". We should ask Werloc, our resident east coast bike mechanic to see if you Yankees coloqually refer to it as "Mung" or something else.
  1. Float Bowl Gasket
    Last Post: 01-13-2014, 11:20 PM
  2. Putting in gear kills the bike.
    By Tammy Diane in forum Technical Help
    Last Post: 08-13-2013, 02:06 PM
  3. Putting on Protaper bars this weekend
    By stephenmarklay in forum Performance and Customization
    Last Post: 04-21-2013, 06:47 PM
  4. bike dies when putting into gear
    By crossent in forum Technical Help
    Last Post: 04-04-2012, 10:00 AM
  5. Float Bowl Gasket Sealer?
    By rmoore2112 in forum Technical Help
    Last Post: 12-04-2011, 08:35 PM
