Gerrys Valve Adjustment Tool
Results 1 to 10 of 15
Like Tree52Likes
Thread: Gerrys Valve Adjustment Tool
    Poway CA.
    2,100
    Your valve tool works great! I used it on Purples bike last weekend and it make the process enjoyable. Its one of those must have tool in my box. Thanks for your innovation.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Thanks Ron. What you got was an idea that became something real. The first of the first, a few days after it fell from the spindle of my lathe.
    This is part of the evolution; a bit shorter so it can be used with the tank still in place. Gerry
    Take care my Friend.........
    18,701
    It really is a sweet tool, Gerry is a creative genius.
    SanDue and TWilight like this.
    Paradise, Calif.
    3,513
    Thanks Fred.
    Friendly Fred gave me this idea. High power magnet inset into the business end of the tool to minimize fumbling. This particular tool has been sent off to the upcoming 2015 Russ Memorial Rally. You don't want to drop this puppy in the dirt.
    Wiping off all the micro particles will take some time. Gerry
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Gerry,
    Now you need to invent an add-on tool that will find the missing nut when it falls inside the engine.
    I suppose that's what the magnet is to prevent from happening.
    jb
    TWilight, SanDue and Gerry like this.
    18,701
    Try taping a small rare earth magnet to a zip tie to fish around. I have one made from a magnet the size of a aspirin but half as thin.
    SanDue likes this.
    May 2014
    Yooper, MI
    1,510
    I was looking to get something.
    How much?
    Mel
    Mel is offline
    Senior Member Mel's Avatar
    Jan 2013
    San Luis Obispo, Calif.
    1,174
    I haave not used this tool yet, but it doesn't take any imagination to know this tool is great.
    Thanks Gerry,
    Mel
    Paradise, Calif.
    3,513
    The non magnetic tool price was set by a forum member at $20 shipped. I was happy with that. The magnetic version requires a bit more tooling so I would think $25 shipped would be fair. Send me a personal message instead of posting in this thread. Thanks. Gerry
    FL. GA, NC
    2,396
    Gerry,
    I was getting ready to use your non-magnetic version when this went missing.
    I tried using a dental mirror and a magnetic probe (in the photo) to no avail.
    Here's how I finally found it:
    This was not the way I wanted to spend the day before the Turtlepalooza.
    I looked for a nylock replacement for the nut but could not find one in local hardware stores.
    It's a M6 but with a fine thread pitch...less than 1.0
    ...while I was in the deconstruction mode, I decided that I would finally replace my stock sprockets and chain.
    jb
    TWilight, SanDue and admiral like this.
  1. first valve adjustment scares.
    By the weiand one in forum Technical Help
    Last Post: 11-03-2014, 04:33 PM
  2. Valve adjustment(s)
    Last Post: 06-26-2013, 02:50 PM
  3. Valve adjustment
    By Scotto560 in forum Technical Help
    Last Post: 03-13-2012, 12:07 PM
  4. Valve adjustment?
    By Matthew Rowland in forum General Discussion
    Last Post: 02-07-2012, 11:15 AM
  5. Valve adjustment specs.
    By phelonius in forum Technical Help
    Last Post: 11-05-2010, 01:58 PM
