Spoke tool
Results 1 to 7 of 7
Like Tree6Likes
  • 1 Post By Fred
  • 1 Post By Purple
  • 4 Post By Peterb
Thread: Spoke tool
    Junior Member Gunny's TW's Avatar
    Jun 2015
    6
    Spoke tool
    Hey Guys,
    can anyone tell me what size the hex is on the spokes so i can get a spoke wrench?
    Or is this a common size.
    Thanks
    Hailey, ID
    3,424
    7mm. Or you can just use a small crescent wrench, as long as your nipples are not rusted. But unless you are experienced at wheel truing you should read this thread: https://tw200forum.com/forum/technica...h-process.html
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    19,171
    Nice helpfull response Rocky. I was tempted to say something snide, rude and qwerty-esque like "Go measure your bike's spokes yourself, it is quicker than asking and waiting for a response" but then I remembered all new members deserve a little consideration at first. Later on we'll tease Gunny mercilessly. Welcome Gunny'sTW.
    littletommy likes this.
    Senior Member gamorg02's Avatar
    May 2014
    Central NY
    174
    the ebay spoke tools work great, the done bone looking ones.
    Mar 2015
    Ynys Môn
    4,674
    *looks at OP's nick - decides against*
    CJ7Pilot likes this.
    - Hidden Content
    DKV
    DKV is offline
    Member DKV's Avatar
    Aug 2013
    Wisconsin
    66
    5.8 mm
    2002 229 6 speed, 241's, emulators blue 2 1/2 130mm 5/8" spacer, 2" powermadd, 714's, jimbo, seat concepts 1/2" gel, tiny tach, carb fuel 2mm BELOW joint at ctr jets 32 132 china needle clip ctr and shorter spring, sprockets 16 52-55 x chain, banshee shock spring rate 700 lbs/in 1 1/2" sag 3" race sag limited 1" to cross member ( 1/8" higher race sag than stock shock and spring when there set on top circlip for ME) modded pegs, kickstand, air screw, seat bolts, etc
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,493
    I just went out to the garage and measured my nipples. Hey hey keep your pants on boys and girls. I want to buy some spoke wrenches to fit my TWs and looking online left me confused so I decided to check for myself with some digital calipers and this is what I found. Front and rear on my 1999 were 5.6 mm, Rear of my 2015 was 5.6 mm but the front spoke nipples are 6.0 mm.
    All of the spoke diameters are 3.3 mm except the spokes on the front of my 15 where they are 4 mm which I suspect is due to the more powerful disc brake.
    I always understood that all TW wheels have 32 spokes however tonight I realized that only the rear wheels have 32 spokes whereas the fronts have 36 spokes on both my 99 and 15.
  1. Spoke Woes
    By the-wild-man in forum Technical Help
    Last Post: 08-17-2015, 03:08 PM
  2. wheel spoke broken
    By jim in forum Technical Help
    Last Post: 12-02-2012, 06:46 PM
  3. Rear Rim Spoke Count
    By unclejemima in forum Technical Help
    Last Post: 01-13-2011, 01:11 PM
  4. Wanted - 1 spoke
    By retro in forum TW200 Classifieds
    Last Post: 10-15-2010, 07:47 AM
  5. Spoke Help!
    By retro in forum General Discussion
    Last Post: 09-21-2010, 07:30 AM
spoke wrench
tw200 rear spokes
tw200 spoke size
tw200 spoke wrench size
