Spark plug feedback
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Like Tree16Likes
Thread: Spark plug feedback
    Senior Member HKLBRY's Avatar
    Mar 2014
    Creswell, Oregon
    175
    Spark plug feedback
    This is my first time pulling the spark plug on my 2103 TW, (3100 miles) and haven't done any spark plugs before on any vehicle (never needed too).
    Looking at my spark plug can I get some feedback as to how it looks?
    OK? Too Lean? Too rich? If too lean or rich, should I make any adjustments? And what adjustments should I make?
    I am currently running a Jet Kit and have it set up as ProCycle's starting point setup of a #122.5 Main Jet, #34 Pilot Jet, and 1 shim.
    Thanks for the advice, Dan
    Hidden Content 2013 TW200
    Seat Concepts seat, Cycleracks rear rack w/pannier brackets, Clarke XT350 Translucent fuel tank, 90` fuel filter, Cycra Probend handguards, DMO footpegs, Kick Starter, Shortened Tail Lights, Ricochet Skid Plate, High Fender Mod, Shinko 241 Trials front Tire, Stock Rear Tire, Upgraded chain, Procycle rear bracket and LED brake light, Jet Kit, Powermadd 2" handlebar riser, seat bolt mod with cables, Versa Pack Tank & Pannier Bags, $1.00 Dairy Crate, NelsonRigg mini tank bag, 14/47
    Spokane, Washington
    17,289
    A top view would help seeing it better, but from what I can see, it's not too lean nor too rich. If the bike runs well, leave it right there.
    Peterb likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,289
    Does it start and warm up quickly and has good response, no flat spots? From start to wide open on the road?
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,289
    Ok. Personally, I'd like to see it just a touch richer.
    Fred likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,289
    Hopefully, you did a plug chop on it. Ran it for about a mile WOT , hit the kill switch, pull the clutch? Yank the plug, check?
    jeffrolives likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,289
    More accurate.
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,289
    You probably don't need to go a mile, perhaps a half a mile. Take it briskly through the gears, ending up in 5th and WOT for a good little bit, then kill it, yank the clutch in, pull the plug, put in a spare, head home and look at it closely and go from there.
    admiral likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,289
    You want to get a good light and look down on the side of the insulator. You want to see a chocolate brownish ring down there. (A correct plug chop would entail cutting some of the threads off so you could really see, that's why they call it a plug chop, but try a good light first. The color might be instantly recognizable.) If it is that color (chocolate brown) or a tiny bit darker, the main jet is right. If it is lighter colored than that or whitish, it's too lean and you need a richer main.
    You can check the shimming on the needle (flat spot mid throttle) the same way if you do your plug chop exactly halfway between off throttle and WOT. If it's light colored, you need one more shim or more. If it is chocolate colored or a tiny bit more, it's probably correctly adjusted.
    Better on the slightly rich side, than lean.
    Hope that helps, keep us posted.
    Carb adjustments should be the last thing you do as far as adjusting and tuning on the engine. So, in other words, the valves would have been adjusted, the air filter serviced, new gas filter, stuff like that.
    admiral likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Mar 2015
    Ynys Môn
    4,571
    I did look it up on google images to begin with - this is the shortened version
    The long version is here http://www.motorcycleinfo.co.uk/reso..._condition.jpg
    But as Littletommy says - after a while you'll do your head in trying to diagnose a plug too far - if it works fine, leave it alone. I spent ten years on two-strokes, as much time pulling plugs as anything else - don't get me started on dialing in heat values for triples ..........
    I applaud your curiosity - but your plug looks fine ..............
    jeffrolives and admiral like this.
    - Hidden Content
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,047
    The ceramic which is the white part surrounding the electrode should have a light toast color as shown in the above Carbureted photo. Too white is too lean and too dark is too rich. I would try to richen your bike just a tad as LT said and leave it alone.
    1987 Yamaha BW350 Big Wheel
  1. Free Spark Plug
    By Larry in forum TW200 Classifieds
    Last Post: 06-13-2015, 03:38 PM
  2. Cracked Spark Plug
    By RainWillFall in forum Technical Help
    Last Post: 05-28-2013, 07:09 PM
  3. Replies: 2
    Last Post: 07-21-2012, 12:44 AM
  4. Spark plug
    Last Post: 05-09-2012, 08:19 AM
  5. Spark plug pic
    By mjlater in forum Technical Help
    Last Post: 03-24-2012, 05:13 PM
lean rich
