I want to install a lighting kill switch for my new TW200
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Dryden-Tdub
Thread: I want to install a lighting kill switch for my new TW200
    Junior Member crowminator's Avatar
    Jun 2015
    Waynesboro Ga
    3
    Hello everyone, brand new member here. I bought a new TW200 this weekend. I plan to use it to get around the local plantation fields here in Burke and Screven county Ga. I hunt hogs and also deer with a crop damage permit at night. I use thermals and night vision goggles to navigate once I am off road. I need a kill switch to disable all the lighting on the TW200. Removing the 20A fuse that kills the lights also kills the ignition, so I cant bypass that circuit. Is there some way I can add a kill swith to the four wire ignition switch plug? I think that would also kill the ignition as well. Anybody have an idea, other than switching everything individually. I dont want seperate switches for each individual light. It would be great if somebody can build a switch that will plug into my existing wiring harness, without having to cut and splice. I am willing to pay for something like that. My email is [email protected]
    Apr 2014
    Dryden NY
    6,336
    Quote Originally Posted by crowminator View Post
    Welcome Crow. Scroll to the bottom of the page. There you will find a section called "similar threads". Your answer normally lies there. If, after researching there you can't find the answer, someone will jump in with newer ideas.
    Tom
    littletommy likes this.
    Senior Member RobG's Avatar
    Jan 2015
    Fulltime in an RV (currently PNW)
    1,076
    This is pretty easy. I installed a headlight kill switch on my TW, so all you need to do them is add the tail and turn signal DRLs to that using a relay. The only wire I'm not sure how to find (easily) is the taillight wire; the others can be found under the plastic headlight cowl. With some bullet connectors for the factory wiring and flat blade connectors for the relay, you could wire it up without cutting any factory wires, so it could be returned to stock.
    Rob
    '12 Suzuki V-Strom DL650
    '96 Suzuki DR650
    '92 Yamaha TW200
    Hidden Content - Organize your rides online!
    Sep 2012
    Northwestern Oregon
    1,092
    Jun 2015
    Waynesboro Ga
    3
    Will the TW200 continue to run after the battery is disconected ? If I install a battery kill switch as suggested in another thread, will the TW200 continue running if the battery switch is turned off after the bike has been started ? That seams like the simplest solution
    Edit. The TW200 continues to run if the battery is completely disconected. Unfortunately , so does all the lights
    Looks like six switches are needed to turn off four side markers, headlight, and tail light.
    Jan 2015
    1,076
    That sounds like a bad idea; the stator output is sent into the battery to charge it; with noplace to go, I'd have to assume it would stay in the stator and burn it out. That or it'd overheat the regulator... unless the regulator is designed to handle that and just shunt it off as heat.
    '96 Suzuki DR650
    '92 Yamaha TW200
  1. Kill button location?
    By Landser in forum Performance and Customization
    Last Post: 10-02-2014, 08:10 PM
  2. High visibility LED lighting for TW200
    By garethllewelyn in forum General Discussion
    Last Post: 05-31-2014, 10:18 AM
  3. Proper way to install a Blackout switch?
    By brownie2 in forum General Discussion
    Last Post: 11-17-2010, 09:47 PM
  4. Kill Switch Relay
    By twmonae in forum TW200 Classifieds
    Last Post: 09-02-2010, 08:46 PM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 06:50 AM
tw200 headlight switch
tw200 turn off headlight for offroad riding
