Help! 1988 tw200 running problem
Results 1 to 10 of 11
    Junior Member NJTW54's Avatar
    Jun 2015
    South jersey
    10
    Hey guys still having sort of a problem with my tw. It's been running great but every once in a while it will bog down .... Especially lately in 5th gear cruising at around 35-40 it will sort of sputter as I'm going ... It feels like a loss of power and it does it for a bit then stops, then will do it again. The carb is pretty much brand new and was just cleaned along with the tank, any ideas would be greatly appreciated, thanks
    Thankful for all of my friends!!
    17,625
    Pretty much new? Might be running lean. The air/fuel mixture screw should be around 2 1/2 turns out.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member jeffrolives's Avatar
    May 2015
    NW Iowa
    343
    Got fuel filter?
    Jun 2015
    South jersey
    10
    Ok, and the fuel air mixture screw is the small brass one correct and yes it is 2 1/2 out.. And no there isn't a fuel filter on there. Could that really be cause cause of that. It really only does it at high rpm...
    Senior Member Jon62602's Avatar
    Feb 2015
    Redding Ca
    604
    I had the same problem with my Razz I tried cleaning the carb, cleaned the tank, messed with the electric stuff but all I had to do was put the airbox on it.
    Jon
    2007 Yamaha TW200Hidden Content
    Tusk D Flex Handguards, ProTaper Pillow Top grips, Yamaha crossbar pad
    Jun 2015
    South jersey
    10
    Was the air box missing... Or just on incorrect in your case?
    Senior Member silverwing's Avatar
    Herman, MN
    326
    Take the carb off and check and clean every passageway, hole where fuel can possibility pass through and double check again. Also check fuel flow from the tank, should be a good steady stream. I had a Polaris ATV that had shavings in the carb since new, cleaned it out and ran good.
    Feb 2015
    Redding Ca
    604
    Quote Originally Posted by NJTW54 View Post
    I just got it and it was in a pile of plastics and lights so it was my fault.
    Jon
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    There was a thread on the little piece of foam on the bottom of the seat and what it's for.The foam is there to block the wind from forming a vacuum and sucking the air out of the carb at higher speeds and causing the very same problem.
    Something to look into.
    7,012
    If you take the carb apart spend $5 or whatever and buy a brand new #114 jet and replace the one that is in there. I don't care how good it looks, how few miles are on the bike, etc., if you have a 1988 carb replace that jet. I did both of my 1987 TW's that were running very poorly at high speeds and it made a world of difference. Good luck. Tony
  1. Replies: 25
    Last Post: 06-06-2014, 11:31 PM
  2. FS: Oregon - 1988 TW200
    By MBGraphix in forum TW200 Classifieds
    Last Post: 03-21-2014, 07:54 PM
  3. parting out running 1988 tw200
    By aclambert in forum TW200 Classifieds
    Last Post: 10-15-2012, 11:04 AM
  4. 87 running problem- bad cdi?
    Last Post: 08-22-2012, 02:31 PM
  5. 1988 tw200 - FS in VA
    By bkfj40 in forum TW200 Classifieds
    Last Post: 08-02-2012, 05:05 PM
