Cable has probably just stretched a bit with normal use. I like to maintain a bit of adjustability at the perch for on-the-trail adjustments so typically make major adjustments at home by extending the cable length adjusters at the case. You might wish to also confirm that you are getting full travel at the handlebars when you pull in the clutch lever, that lever is not contacting anything limiting travel.
Connect With Us
