TW 200 idles fine but cannot give it throttle?
Results 1 to 9 of 9
Like Tree13Likes
  • 1 Post By cmercon
  • 2 Post By rbm
  • 1 Post By cmercon
  • 1 Post By rbm
  • 3 Post By littletommy
  • 2 Post By will
  • 1 Post By cmercon
  • 1 Post By Purple
  • 1 Post By elime
Thread: TW 200 idles fine but cannot give it throttle?
    Member cmercon's Avatar
    Feb 2013
    Vermont
    86
    Exclamation TW 200 idles fine but cannot give it throttle?
    1987 TW200 Brand New CDI (dont ask) brand new air filter, brand new air filter boot and brand new intake boot.
    Bike runs fine with choke halfway out. You could ride it all day but put the choke in and all you can do is idle.
    Carb appears to be clean as I have had it off and cleaned it out about 5 times now.
    Any hints tips suggestions. I have uploaded a video to youtube to better illustrate the issue,
    Thanks in advanced!
    jtomelliott49 likes this.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Pilot jet.
    jeffrolives and jtomelliott49 like this.
    Feb 2013
    Vermont
    86
    Clogged?
    rbm
    rbm is offline
    Jan 2011
    4,300
    Yep. Mine was the same way when I got it.
    Spokane, Washington
    17,291
    I wouldn't try to clean it, it's probably corroded and eaten up somewhat since it's an 87. Buy a new pilot jet kit.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member will's Avatar
    Jun 2015
    119
    i had the same problem, get a full carb rebuild kit.
    Feb 2013
    Vermont
    86
    Turned out to be a faulty air filter? I took the air filter off of my 2014 and put it on the 87 and it ran perfect.
    Mar 2015
    Ynys Môn
    4,571
    The pilot jet adjusts the air/fuel mixture — but if the air filter has had it, the results will be the same. Could have been either, even a cracked intake boot will do it, hard to notice sometimes. Fortunately, you had another bike to swap parts from.
    Well done for finding it — and for letting us know the end result — far too many threads end with suggestions — not solutions — and it’s the solutions we learn from ……………
    - Hidden Content
    6,976
    The idle mixture screw is open 2 1/2 turns......
  1. Replies: 26
    Last Post: 08-31-2014, 08:25 AM
  2. Idles fine, then sputters when I give it the gas
    By PSLADE in forum Technical Help
    Last Post: 08-21-2014, 03:00 AM
  3. idles fast then dies
    By carp123 in forum Technical Help
    Last Post: 09-25-2012, 09:41 PM
  4. Bike idles fine on stand, dies when upright
    By Sloppy in forum Technical Help
    Last Post: 07-07-2011, 07:28 PM
  5. TW200 Idles and Dies
    By Quicksand in forum Technical Help
    Last Post: 10-22-2010, 03:57 PM
