Front end wallows/wanders after Shinko 241
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Like Tree37Likes
Thread: Front end wallows/wanders after Shinko 241
    Senior Member RobG's Avatar
    Jan 2015
    Fulltime in an RV (currently PNW)
    1,076
    I installed a new Shinko 241 tire on the front a week or so ago. A few days later I ended up on the main road for a short ways, and when I got up over 50 mph, the front end started wallowing, or wandering. It would get worse the faster you go, so I had to back off. I checked the tire pressures and aired them up to around 22 psi and tried again, same result.
    I know my left fork tube is slightly bent, as my bars are usually "crooked" when going straight, so I wonder if this could be responsible? I haven't found an affordable fork tube to replace it. It never did this with the old stock front tire.
    Thoughts?
    '12 Suzuki V-Strom DL650
    '96 Suzuki DR650
    '92 Yamaha TW200
    Hidden Content - Organize your rides online!
    Senior Member TWROG's Avatar
    Dec 2014
    Stockbridge GA
    807
    What size did you get? If its shorter than what you had, effectively lowering your front, that can cause some stability issues at speed.
    Smitty Blackstone likes this.
    2009 TW200 "Cracker" - His fun ADV bike
    2006 TW200 "Blue" - Her fun ADV bike
    2011 XL1200X "48" - My cool bike
    1977 KZ650 - My vintage sport bike
    Jan 2015
    1,076
    It only comes in one size... 4.00/18.
    Lots of people are running this tire and I haven't seen any of them reporting this problem...
    '96 Suzuki DR650
    '92 Yamaha TW200
    Mar 2015
    Ynys Môn
    4,571
    Try lifting the front wheel off the deck – rotate – and look closely
    It may be that the tire hasn’t seated properly – or your wheel is out of whack – (or even the tire)
    Odd that it only comes on at speed though – usually indicates a balance problem – but with a known bent fork, you really need to get that sorted out first ……………..
    - Hidden Content
    Spokane, Washington
    17,291
    Do you have the fork brace on the bike? (the metal piece that the stock fender is mounted on) Or have removed it mounting the high fender kit? This can cause wandering if it is not there. Also, too much air pressure means your contact patch on the road is smaller and therefore more subjected to the small imperfections in the road that we always encounter. The only other things I can think of are wheel bearings and the steering head bearing. If the tire is worn out and cupping it can cause shimmying and a wobble too, but that doesn't seem to be the problem.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member Dubster's Avatar
    Nova Scotia Canada
    583
    I have the Shinko244 on both TW's and have noticed the same thing at high speeds. In fact if I shake the bars it will induce a slight speed wobble. A bit unnerving at first but I just got used to it as it never seemed to get to the point of loss of control and stops as soon as I roll off the throttle. I did however put a Scotts stabilizer on the 03 but the same thing still happens at speed.
    I will be trying a different tire when the 244's wear out and was thinking the 241 might be the answer till I read your post.
    littletommy likes this.
    09 DL650 V-Strom "Function over Form at a Superior Price"
    09 DR650 "Hooliganizer"
    03 TW200 "No Road---No Problem"
    81 Z50 "Just Because"
    98 Honda Valkyrie "Fast as [email protected]&K"
    02 Tw200 " Camouflaged Redneck Edition" Sold to Son-in-Law
    73CT Trail90 "The most fun you can have under 100cc's" Sold. Had an offer I couldn't refuse.
    Jan 2015
    1,076
    AHA! See I'm not the only one.
    The tire is brand new; like, maybe 20 miles on it so far. The steering and wheel bearings are also new. I'll check the wheel to see if it's wobbling, and I'll even put it on my balance stand and balance it. Maybe that's the answer.
    '96 Suzuki DR650
    '92 Yamaha TW200
    Mar 2015
    Ynys Môn
    4,571
    I'm presuming you also have a knobbly on the back ?
    Ran into a similar problem earlier this year trying to run a road tire on the front and a knobbly rear ............
    - Hidden Content
    Senior Member will's Avatar
    Jun 2015
    119
    I had this problem with a knobby front and street back on a crf250. Could be something this simple.
    Member uncle tim's Avatar
    Mar 2014
    Lakota ND
    79
    After drinking the cool aid and changing my out my stock tire for a golden boy I've noticed this occasionally too. It really scared me when it happened first. Kinda still scares me. I think I may try a different tire at some point, maybe the kenda but idk. I've noticed its usually happens to me on really windy days or if I'm sitting too far forward..
  1. Shinko 244 Front Tire
    By Phantom99 in forum Performance and Customization
    Last Post: 07-31-2017, 12:30 PM
  2. Shinko 244 or 241 Front Tire? Your Preference?
    By Dave-o in forum Performance and Customization
    Last Post: 04-29-2017, 03:44 PM
  3. MHoMadness wanders NORTH!
    By mhomadness in forum Trails, Off-road, and Adventure Riding
    Last Post: 04-18-2015, 09:45 PM
  4. front tire shinko 244 5.10
    By cccan in forum Performance and Customization
    Last Post: 06-10-2014, 06:45 PM
  5. FS: Shinko 244 "Golden Boy" front tire (NY)
    By 98940 in forum TW200 Classifieds
    Last Post: 05-18-2012, 03:34 PM
shinko 241
shinko 241 feels light upfront
shinko 241 for tw200
