Rear Sprocket Bolt Size
Results 1 to 8 of 8
    Member Rezolution's Avatar
    Jan 2011
    Portland, Pacific Wonderland
    30
    Need a set to bolt up my 60 tooth on the off road wheel/tire that I'm setting up.
    Want to have them in stock when it arrives.
    Swear it was posted somewhere on the old forum...
    Thanks!
    TW acquired August '08, Sold October '19.
    It was a serviceable tool that was no longer needed and passed on in good repair.
    6,985
    I used 5/16" grade 8 bolts, grade 8 nuts, grade 8 washers, and grade 8 lock washers plus blue locktite . Bolts for the dual sprockets were 1 1/2 " long with threads only on the lower half. For a single sprocket I bet an inch would do it but you better measure first.
    In my opinion grade 8 is overkill but since they were available I used them.
    Or you could go with 8mm bolts, nuts, etc. That would do it too.
    Nov 2010
    Frostbite Falls Ill
    2,719
    eight milimeter X 1.25 metric grade 10 something for hardness.
    Phelonius
    Phelonius
    Jan 2011
    30
    Mission accomplished!
    I bought a set of 5/16 x 1 1/2" bolts, saving about half from the price of metric graded bolts.
    Mic'd them out compared to the stock bolts and couldn't get a measurable difference in diameter.
    So you're buying bolts that are way longer than necessary to get the 1/2" of of unthreaded shoulder.
    Suppose you could be anal and cut off the excess, but they don't even do that from the factory.
    I just used nyloc nuts.
    6,985
    Quote Originally Posted by Rezolution View Post
    I considered nylocs but they didn't fit into my grade 8 overkill theme.
    Desert, SoCal
    7,369
    FWIW, late models have slightly thicker wheel flanges than early wheels. The bolts are long enough, but the threaded portion is too short. may not be long enough for some aftermarket sprockets with an inset bolt pattern. You'll probably need to add a washers or get deeper threaded bolts, Make sure your grade 8's are threaded deep enough. In my experience the thread length on late models is sort of a bastard size.
    I'm the king of overkill, but plenty of people including myself are running as large as 70T sprockets and riding them hard, on stock hardware.
    13 hp. Just sayin.
    Member n8bone's Avatar
    corn desert, IL
    46
    That's the issue I ran into when I swapped the stock 50T for a JT 47T.
    I bought some bolts instead of washers. The bag says M8X30 931-10.9 They work well. I've got 3 more sets of 6 because they were bought as a bag of 25. Anybody need a set?
    Hidden Content : KLR pegs, 47t sprocket, cyclerack, Bridgestone 203/204, D.I.D. o-ring chain, Jimbo shield
    Hidden Content : gone to a new home. it was my first...had it for 14 years. miss it sometimes.
    6,985
    With dual sprockets 1 1/2" bolts are about the right length.
  1. What size muffler bolt
    By PalmStateCrawler in forum Technical Help
    Last Post: 01-24-2013, 12:05 AM
  2. Replies: 0
  3. Front Sprocket - keeper Bolt different size
    By ezman671 in forum Technical Help
    Last Post: 10-03-2011, 12:54 PM
  4. Front Motor Mount Bolt Size?
    By sorethumb in forum Technical Help
    Last Post: 08-24-2011, 03:23 PM
  5. good replacement chain for use with stock sprocket size
    By grt1982 in forum Technical Help
    Last Post: 07-11-2011, 05:07 PM
85 magna v65
85 v65 magna
931b sprocket rim
aftermarket handlebars for 85 magna
blt size tw200 sprocket
cr250 rear sprocket bolt thread size
longer sprocket bolts
rear sprocket bolts tw200
v65 magna
v65 magna hp
which rear sprockets bolt on
yamaha v65
