Another Oil Drain Plug Stuck & unStuck
Results 1 to 5 of 5
Like Tree12Likes
  • 9 Post By JS5owner
  • 1 Post By rbm
  • 1 Post By mrlmd
  • 1 Post By WECSOG
Thread: Another Oil Drain Plug Stuck & unStuck
    Senior Member JS5owner's Avatar
    Palm Springs / Desert Hot Springs
    308
    Yep, for the 3rd time I've gotten my oil drain plug stuck and ended up rounding off the soft metal hex head! DOH!!! You'd think I would have learned on the first and second time. Well this time it was really stuck... my final solution on this one, drill a hole through the head, stick a Phillips head screwdriver in, warm the engine and then give it a swift kick/push. BINGO, finally it came off. Here are a couple of pictures of the removed drain plug with hole. I installed a new plug with anti seize and used my torque wrench... perhaps I've learned. <grin>
    2007 TW "Muley": Cyclerack rear, 55 tooth rear sprocket, Duro Power Grip & Shinko SR241, Clarke tank, Ricochet bash plate, Mule hitch pin quick seat removal, Trail Tech Vapor w/ Dashboard, hardwired Garmin 60csx & 205w, 12vdc adaptor, independent high beam off/on and signal beeper, modified seat.
    2000 Yamaha V-star 650 Custom - [sold]
    2009 Yamaha WR250R - "Willie Boy" the slimmer faster brother of my Muley.
    2009 Hidden Content . Wow, what fun on the highway!
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Nice work!
    littletommy likes this.
    Senior Member mrlmd's Avatar
    1,153
    Always remember, anytime you want to change engine oil, rear diff oil, trans oil in a car, lower gear unit oil in an outboard, or any other thing like that you are going to do, remove the fill plug first, to make sure you can get that out, before you remove the drain plug - otherwise you may be screwed having emptied all the lubricant out and then having no way to fill it back up again.
    BTW, that was a neat trick, and I would probably just put that back in so I knew I could get it out again. Or, drill out the new plug like that, just in case.
    Member mrx916123's Avatar
    May 2011
    93
    I had the same problem, but I used a nail set which worked excellent.
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    742
    Quote Originally Posted by mrlmd View Post
    Good idea. Although with the Tee Dub, you could always lay the bike on its right side and pour the fresh oil in through the drain port.
    Fred likes this.
  1. Drain plug stuck
    By georgeDubya in forum Technical Help
    Last Post: 02-04-2016, 06:23 PM
  2. another tw another stipped drain plug
    By triple3jrb in forum Technical Help
    Last Post: 03-07-2012, 02:42 PM
  3. wtb OIL DRAIN PLUG
    By rvtjonny in forum TW200 Classifieds
    Last Post: 02-06-2012, 07:35 PM
  4. TDC Plug Stuck in Crank Case
    By Snake2715 in forum Technical Help
    Last Post: 08-10-2011, 08:26 PM
  5. Oil Drain Plug Stuck
    By hoginthebog in forum Technical Help
    Last Post: 06-27-2011, 03:57 AM
stuck oil plug drill a second hole
tw200 oil drain plug stuck
Tags for this Thread
