does the TW supply AC or DC to the headlight?
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By ZDR1
  • 2 Post By arbolmano
Thread: does the TW supply AC or DC to the headlight?
    Senior Member badcat's Avatar
    Jan 2015
    Auckland New Zealand
    357
    does anyone know?
    i want to run LEDS that need DC.
    ken
    Spokane, Washington
    17,286
    Quote Originally Posted by badcat View Post
    does anyone know?
    ken
    Everything that runs back to the battery and run's the bike's equipment is D.C.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    Its DC.
    That being said you may better be served by running the lights direct off the battery with a relay to control them off the headlamp if you plan on retaining the factory light. For instance i set mine up to only come on with the high beams are on and the lows shut off the led lamps so i dont blind oncoming drivers.
    Jan 2015
    357
    thanks - i keep thinking of the BW as it doesn't have a battery - headlight is AC.
    k
    Jan 2015
    357
    thanks - i'm looking at replacing the headlight with an LED array.
    but all info is great!
    ken
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    On a motorcycle, the only part of the electrical system that has AC power is the charging system, which uses the rotation of the engine to generate enough electricity to operate the bike and maintain/charge the battery. The regulator/rectifier takes the AC voltage from the stator and changes it to DC so that the system can use it, while it regulates the amount of voltage being put into the system.
    The lights, starter, ignition system, and any other system that requires electricity on a bike uses DC power. Power from the battery positive terminal travels through a switch or series of switches, through a fuse, through the load (lights, etc.), through the chassis as a ground and back to the battery through the negative terminal, creating a circuit.
    It's possible to have an AC headlight but very uncommon.
    GTG likes this.
    Senior Member arbolmano's Avatar
    Feb 2012
    Arroyo Grande, Ca
    782
    Well actually.....it depends on what year TW you have. The oddball 1987 uses the same system as the BW! AC to the headlight, direct from stator.
    Also the stator generates AC which is rectified to DC. These can fail. For items that could be fussy you would be better off running your lights
    from battery and switch it with a relay. This is also a trick if your lights pull more wattage than stock. On some older bikes heavier wires were the
    trick to better lights. BMW esp would undersize the wire so when you installed a higher wattage bulb all sorts of bad things happened.
    GTG and badcat like this.
    Tonto on the "Left Coast"
    1987 TW200 (2) 2015 BMW F700GS
    More Wagging and less Barking
    "Enjoy yourself, it's later than you think"
    Make Love not War
    Jan 2015
    357
    Quote Originally Posted by zdiver1 View Post
    yeah - older trail bikes - with no battery have AC headlights.
    i have two of them!
    k
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    742
    Quote Originally Posted by arbolmano View Post
    I'm not sure what you're referring to that can fail (specifically on the '87), since all bikes that have a DC supply derive charging current that begins as AC and is then rectified to DC.
  1. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 01:32 AM
  2. TW200's why always in short supply?
    By OSOK in forum General Discussion
    Last Post: 08-16-2013, 11:23 AM
  3. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
  4. Tractor Supply' sells TW200s
    By DRF64 in forum General Discussion
    Last Post: 04-25-2012, 03:39 AM
  5. Headlight
    By chasejamy in forum General Discussion
    Last Post: 03-19-2012, 10:04 AM
are the lights on a tw200 ac or dc
is headlight ac or dc
