Is there a max length for a front brake cable?
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Lyterx
Thread: Is there a max length for a front brake cable?
    Senior Member Dell's Avatar
    Aug 2012
    139
    I have a 89 TW and put new tires on it. It seems I have okay brake pads, but it is hard to adjust the front brake, and I wonder if the cable has stretched. Is there a spec on this? Thanks.
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    473
    Mine seems the same, I have a brand new OEM one and I will measure it before it put it on.
    1991 TW200
    Aug 2012
    139
    That should tell me if I need to replace it!
    Mar 2015
    Ynys Môn
    4,571
    Dell – you can always move the cam arm around a bit more to take up the slack – but if you’re running on a 25 year old cable my advice would be to replace it anyway
    Especially on something as important as the front brake …………….
    - Hidden Content
    Senior Member RobG's Avatar
    Jan 2015
    Fulltime in an RV (currently PNW)
    1,076
    I was thinking the same thing about mine the other day. I emailed MotionPro about having a new cable made (longer) so I could add another riser... that plus a longer clutch cable. They now want $48 each for custom cables. Gack. Prices have gone up!
    '12 Suzuki V-Strom DL650
    '96 Suzuki DR650
    '92 Yamaha TW200
    Hidden Content - Organize your rides online!
    Aug 2012
    139
    Sounds good, thanks. The cable seems sound; no fraying. My first instinct is to move the nubbin, but I value myself just a bit to much for DIY behavior on the front brake! Even minor repairs to the human body don't compute well with a 30-some $ cable...
    If the cable turns out to be stretched, I might just do shoes as well so I don't have to get into it for a while.
    Jun 2014
    Etters, Pa
    473
    I measured a brand new unused oem brake cable and it is about 50 1/2 -50 5/8 end to end. Hope that helps.
    littletommy likes this.
    1991 TW200
    Aug 2012
    139
    Sure does! 50 5/8 is what mine is. I put 8000 miles on it but don't know about the age. Thanks.
    Senior Member flyhunter3825's Avatar
    Nov 2012
    DePere, Wisconsin
    296
    A speedo and brake cable off a 1980-84 XT250 are a lil longer and will fit right in.
  1. Front brake cable?
    By cmercon in forum Technical Help
    Last Post: 07-07-2014, 08:12 AM
  2. 1998 TW200 Front Brake Cable
    By eldomike in forum TW200 Classifieds
    Last Post: 01-17-2014, 04:36 PM
  3. Replies: 2
    Last Post: 05-28-2013, 11:00 AM
  4. Front brake cable/lever?
    Last Post: 11-09-2012, 02:37 PM
  5. Front brake cable/lever?
    Last Post: 11-09-2012, 01:48 PM
