Can someone post the valve adjustment link....
Results 1 to 6 of 6
    Senior Member Flathats's Avatar
    Jun 2014
    Idaho
    657
    Wife has the computer....and I'm not smart enough to run a smartphone...
    dmo
    dmo is offline
    Member dmo's Avatar
    Apr 2015
    30
    ITEMSPECIFICATIONValve clearance, cold (intake)0.05 – 0.09 mm (0.002 – 0.004 in)Valve clearance, cold (exhaust)0.11 – 0.15 mm (0.004 – 0.006 in)
    Sent from my Nexus 7 using Tapatalk
    dmo
    dmo is offline
    Member dmo's Avatar
    Apr 2015
    30
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Jun 2014
    Idaho
    657
    Thanks to both of you!!!!
    dmo
    dmo is offline
    Member dmo's Avatar
    Apr 2015
    30
    I bought a subscription to this a while back. Had great instructions with pictures. I use it a lot. http://www.cyclepedia.com/manuals/on...lve-clearance/
  1. Replies: 12
    Last Post: 02-15-2014, 07:14 AM
  2. Replies: 0
    Last Post: 10-03-2013, 02:36 PM
  3. Valve adjustment(s)
    Last Post: 06-26-2013, 02:50 PM
  4. Valve adjustment
    By Scotto560 in forum Technical Help
    Last Post: 03-13-2012, 12:07 PM
  5. Valve adjustment?
    By Matthew Rowland in forum General Discussion
    Last Post: 02-07-2012, 11:15 AM
