Need help starting my TW200
Results 1 to 10 of 18
Like Tree26Likes
Thread: Need help starting my TW200
    Junior Member 2005TW200's Avatar
    Jun 2015
    Knoxville, TN
    8
    I have a 2005 TW200 (I bought new) that hasn't been run for about 4 or 5 months. I can get it to run only with the choke wide open. After it starts wide open and I slowly close the choke, about halfway in it stops. I have taken the 2-year old carb apart and cleaned and blown out everything. Adjusting the pilot screw helps some, but I can't get it right.
    Historical background: Unfortunately about 2 years ago I had a similar problem. I hadn't properly maintained it while it sat and the carb filled with gunk (shame on me). Last time after creming the rusty tank, installing a fuel filter, and cleaning the carb several times (by using excellent help from this forum), I had to take it to the dealer to get it to run. They couldn't get it to run either and replaced the carb because they said it had an air leak somewhere. Hence the 2-year old carb. Incidently, it never did start well after this work. I live in east Tennessee where condensation can be a problem, i.e. cold winters and humid summers. I like the bike, but it is frustrating to keep running. It has always been cold natured. I also have a 2003, 1100 V Star Classic that gets more riding time...maybe because it is morre dependable and requires less attention.
    Spokane, Washington
    17,283
    Welcome to the forum!
    Typically when this problem surfaces, it ends up being within the pilot jet area. I would suggest getting some Lucus Deep System Fuel Cleaner, or SeaFoam. (The Lucus works better initially for these problems) Seafoam can be used once in a while later to keep stuff clean and running nice. Use the Lucus first. Put in 3 or 4 ounces in the gas tank and run the engine, ride it if you can. Let it sit for awhile, ride it again, continue until you know if it will work or not. This could take a couple days. If it is not any better, the carb has to come apart again and be cleaned.
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2015
    Knoxville, TN
    8
    Thanks for the feedback, littletommy. I'll give the Lucus a try. I use SeaFoam. I've seen your advice on other threads and you seem to be an expert.
    littletommy likes this.
    Spokane, Washington
    17,283
    I'm no expert that's for sure, but I'll give ya the best I got bro!! If you already have the Seafoam, put several ounces in the tank, more than I recommend on the Lucus. But first I might try taking the gas line off from the petcock and putting Seafoam directly in the line and cranking it over to draw some right into the pilot. Keep me posted alright?
    2005TW200 and jtomelliott49 like this.
    1st John 1:9
    John 3:16
    John 3:17
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Drain the tank. Add one gallon of fresh fuel triple dosed with Seafoam and run it. Let it sit for a day and repeat. Repeat three times. Or, clean the pilot jet.
    littletommy and 2005TW200 like this.
    Jun 2015
    Knoxville, TN
    8
    Will do.
    Jun 2015
    Knoxville, TN
    8
    Thanks, rbm. I've drained the tank and the cleaned pilot jet. However, it seems I need to repeat these activities.
    littletommy and jtomelliott49 like this.
    Jun 2015
    Knoxville, TN
    8
    I'll post updates as I try different things.
    rbm
    rbm is offline
    Jan 2011
    4,300
    Quote Originally Posted by 2005TW200 View Post
    Let the Seafoam do its thing, trust me.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    First, I can't believe the dealer made you buy a new carb....absolutely unnecessary...and expensive, unless there is a severe crack or a piece broken off.
    It is definitely the pilot jet and/or pilot jet internal passageways.
    I went through this a couple months ago with my '05 TW, when once again I went off for the season without draining the carb and winterizing the bike.
    The end hole of my pilot jet was completely blocked, and even one of the side air holes on the emulsion tube was clogged.
    The Seafoam is probably the best bet without disassembling the carb again.
    Be sure to remove the pilot screw and squirt some carb cleaner up the hole...make sure the washer and oring are in place when you reassemble it.
    My TW lives a couple of hours south of you, over the mountain from Tellico Plains.
    I would offer my services to you (for free) but I am stuck in FL working on a construction project.
    I should be in NC/TN later in the summer if you are still having problems.
    ....and find another dealer.
    jb
  1. Push Starting?
    By Dave-o in forum General Discussion
    Last Post: 08-06-2019, 03:04 PM
  2. Tw125 not starting
    By BlackCatCycles in forum Technical Help
    Last Post: 05-15-2015, 01:08 PM
  3. Tw200 Cranks Slowly When Starting
    By Hoff in forum Technical Help
    Last Post: 09-07-2013, 08:06 AM
  4. 2005 TW200 Not Starting
    By BWhitty in forum Technical Help
    Last Post: 08-30-2013, 06:17 PM
  5. 2007 TW200 problems starting
    By NEO-snow in forum Technical Help
    Last Post: 08-09-2013, 03:50 AM
Tags for this Thread
