Which Carb Rebuild Kit?
Results 1 to 7 of 7
    Member Mozart 2's Avatar
    Jul 2012
    Millis, MA
    40
    I know there have been a few carb rebuild threads on here discussing "the Ebay kit" but there are several available. What do you recommend for a good basic rebuild kit for a 2006 TW?
    Here are pix of a few that I have found:
    Thanks.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,405
    The one you show from Pro Cycle is a jet kit, not a rebuild kit.
    The second picture down is for the old style slide carb....not for your 2006.
    The other 3 appear to be the same, and are correct for your 2006 CV carb.
    jb
    7,012
    What I have done is to replace the high speed jet with a new #114, the o-ring around the thing the needle float goes in, and get a 2 1/2" o-ring to use for a float bowl gasket -- I have the old style carb. If the needle float leaks then that too will need to be replaced. I cleaned all the parts with an ultrasonic cleaner using Simple Green (others use PineSol but I hate the smell) and replaced any other individual parts that looked bad, but there weren't any.
    My one and only experience buying a carb kit for the early TW carb off ebay was a disaster. Maybe they sent me the wrong kit, or the wrong parts in the right kit box, but it flat out didn't work.
    Here are the parts that came in the kit. They were briefly used once, removed and the old original parts put back in.
    7,012
    This is the thing the needle float goes into and this is a good o-ring to replace (red arrow). It will save a lot of diagnostic headaches by not leaking.
    Jul 2012
    Millis, MA
    40
    Thanks for the review.
    I just ordered this one ($32.12 and free shipping):
    http://www.amazon.com/Shindy-Carbure...etor+kit+tw200
    7,012
    Quote Originally Posted by Mozart 2 View Post
    Amazon.com: Shindy Carburetor Repair Kit 03-892: Automotive
    Please report back how it works out for you.
    FL. GA, NC
    2,405
    That's the kit I ordered a few months ago.
    The parts are imported from Japan by the Shindy Co.
    I haven't used them yet but in side by side comparison to stock Yamaha parts, they appeared identical.
    jb
  1. Carb rebuild kit
    By evilkevin in forum Technical Help
    Last Post: 04-21-2015, 07:18 AM
  2. New Carb Rebuild Kit
    By Mongo357 in forum Technical Help
    Last Post: 01-24-2015, 12:18 PM
  3. Carb rebuild kit
    By FTW200 in forum Technical Help
    Last Post: 07-02-2014, 05:43 PM
  4. carb rebuild kit
    By steelynorm in forum Technical Help
    Last Post: 01-28-2014, 02:38 PM
  5. New carb or rebuild old?
    Last Post: 07-15-2013, 07:49 PM
tw200 jet kit old
