Where does this spring go?
Results 1 to 10 of 10
Like Tree8Likes
  • 1 Post By admiral
  • 2 Post By littletommy
  • 1 Post By Purple
  • 1 Post By methamphetasaur
  • 3 Post By 2Oceans
Thread: Where does this spring go?
    Member 2Oceans's Avatar
    Jun 2015
    Johannesburg, South Africa
    30
    Question Where does this spring go?
    Hi guys,
    I took apart my ignition switch to troubleshoot the intermittent power supply issue.
    While taking the 'cylinder' off the bike a spring popped out and I can't figure out where it is meant to go. I tried it in the position as per the photo, but it didn't feel right. Key was difficult to turn. So I removed the spring, cleaned all the contacts and put the rest back together. Seems to work fine. I would however like to return the spring to its correct place. Any ideas?
    Also, the contacts seem to have been lubricated with something. I have now cleaned this off and want to re-lube ... what type of lubricant would you recommend? (conductive or insulating?)
    Thanks in advance.
    Frosty Hollow
    13,052
    No solution to you're questions, but is your key turning when inserted or just that nothing happened when the key was turned? I'm curious if there are tumblers inside besides the contacts which you're showing.
    Blueduce likes this.
    Jun 2015
    30
    Key turns when inserted. If I put the spring in as per the picture then it turns but doesn't feel right. Looking at it now, I thought perhaps the spring might go in between the black plastic switchplate and the metal "cam" which the spindle fits into. i.e. in between pictures 2 and 3 if that makes sense. So it basically pushes the the switchplate up towards the moving contacts. I just didn't see any telltale scuff marks that are usually left by a spring on either the rear of the switchplate, or the cam. So I'm stumped.
    Senior Member Beeline's Avatar
    Sep 2014
    Arcata, CA
    230
    This is a shot in the dark but is the spring tapered? If so maybe its upside down(?).
    Jun 2015
    30
    Spring doesn't appear to be tapered.
    Spokane, Washington
    17,289
    It's probably the spring that has to be depressed within the ignition to turn it to lock.
    TWilight and goldenhtr like this.
    1st John 1:9
    John 3:16
    John 3:17
    Mar 2015
    Ynys Môn
    4,571
    You'll need a lube that is non-conductive (given that we're at opposite ends of the world, I'm reluctant to name "brands") .............
    TWilight likes this.
    - Hidden Content
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Colorado
    1,163
    If it works without it, then the spring probably goes in the trash. Silly manufacturers and their extraneous parts...
    TWROG likes this.
    Jun 2015
    30
    Quote Originally Posted by methamphetasaur View Post
    Ha ha. Indeed. Sometimes I think they put springs in just for fun to pop out and confuse us.
    Jun 2015
    30
    Mystery solved. Thanks to this excellent thread... http://xjbikes.com/forums/threads/re...-switch.34810/
    I can only assume that the ignition has been worked on before and the spring put back in the wrong place as I never got as far as removing the "retaining plate". Would explain the stickiness of the key before.
    littletommy, GTG and goldenhtr like this.
  1. Replies: 2
    Last Post: 06-06-2014, 08:18 PM
  2. Yay spring!
    By Mukluk in forum General Discussion
    Last Post: 04-03-2014, 05:59 AM
  3. Spring is here!...or somewhere...
    By Tirebiter in forum Off-Topic
    Last Post: 03-27-2014, 06:05 PM
  4. Will Spring ever come ?????
    By pair of jacks in forum Trails, Off-road, and Adventure Riding
    Last Post: 02-28-2014, 09:35 AM
  5. Is it spring yet?
    By wrench-puller in forum General Discussion
    Last Post: 03-13-2011, 07:13 PM
Tags for this Thread
