Oil Filter Question (Picture)
Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By ZDR1
  • 1 Post By ZDR1
Thread: Oil Filter Question (Picture)
    Senior Member Welder's Avatar
    May 2015
    PNW
    113
    I just removed the OEM filter from my 2015 for my 600 mile service. The new Yamaha filter is pleated, the original is not. The ends appear the same. Good to go or do I have the wrong filter?
    Original on left, new filter on right with Yamaha box and part number.
    https://im1.shutterfly.com/media/47a...?tn=1897181972
    https://im1.shutterfly.com/media/47a...?tn=1045719775
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    You are good just don't throw the original away it is reusable for many years.
    littletommy likes this.
    Feb 2014
    Arizona
    4,030
    also at 600 miles you should do a valve check.
    May 2015
    PNW
    113
    Valves checked out perfect : )
    Side note, they must lots of assembly lube in the engine as the old oil that drained out had a super slick feel and the film strength was unlike any other oil I have rubbed between my fingers - felt more like grease other than it was a thin viscosity like an oil.
    Feb 2014
    Arizona
    4,030
    I had a bunch of white Teflon looking stuff in my first oil change.
    May 2015
    PNW
    113
    Same here, stuff in the filter, mine was silver though - nonmetallic, sealant perhaps.
  1. Air Filter question
    By 2000TWThumper in forum Technical Help
    Last Post: 08-04-2014, 08:49 PM
  2. Carb question for DG O Exhaust, K&N Air Filter, K&N Breather
    By fredzaha in forum Performance and Customization
    Last Post: 07-23-2013, 11:35 PM
  3. Help quick air filter question
    By mtngirl in forum Technical Help
    Last Post: 08-21-2012, 12:48 PM
  4. OIL FILTER QUESTION
    By harleyjoe43 in forum Technical Help
    Last Post: 02-03-2012, 06:19 PM
  5. Valve TDC question with picture
    By Snake2715 in forum Technical Help
    Last Post: 08-24-2011, 08:33 PM
