Bike idling funny as well as the neutral light doesnt work.
Results 1 to 5 of 5
Like Tree3Likes
  • 2 Post By TW-Brian
  • 1 Post By Gyroshark
Thread: Bike idling funny as well as the neutral light doesnt work.
    Junior Member Gyrohammer's Avatar
    Sep 2014
    1
    I bought a 2004 TW around a 1.5 years ago. The original owner had the bike sitting for a very long time, when I picked it up it only had around 4700 miles on it. The neutral light used to work fine when I first got it, then stopped working about a month. I didn't think much about it as I knew how to get into neutral without the light. I then was revving the bike to try and see how slowly it fell back down to idle, which took and still sometimes takes a long time. Whilst I was doing this the light came back on again and lasted for about a week, it then shut off and hasn't worked since, its been about 4 months since the light has worked. I tried to take a look at the plugs in the front of the bike that led to the panel with the neutral light and came to the conclusion that I have no idea what I should do with those or how I should check their connections are right. So I unplugged them, sprayed them with some compressed air to try and clean them out which didnt work. Also the high beam light wont work either. The reason I'm looking to get these fixed is because I'm selling the bike and the buyer is a beginner and would like at least for the neutral light to work. Could the bulbs simply be burnt out? The indicator light still works so it cant be that the plug is bad. The bike is stored inside and has sat out in the rain maybe one or two times only for a short time. Any ideas on what I should do about this? is there any more obvious troubleshooting that I've missed?
    Anyways onto the next problem. The bike has never idled correctly really. Even after riding it for about 10 minutes when you pull in the clutch it idles then will start to skip then die, I've had it happen numerous times at stop signs and at intersections. As I said the bike did sit for quite a while so could it be that the carb just needs to be cleaned? The bike also as I mentioned briefly above takes a while to come down to idle if its revved up. Also I've noticed the bike to suddenly idle really high when I pull the clutch in sometimes. For example I'll be cursing along for 10 minutes, pull up to a stop sign and the bike will idle fine. However the next stop sign I pull up to and pull the clutch in the bike will start to idle extremely high. I have checked the idle screw and had to adjust it many times while at a stop sign to keep the bike from revving too high or cutting out entirely. I'm not very skilled mechanically I haven't worked on a bike very in depth at all unfortunately. Any help and/or advice whatsoever with these issues would be awesome, and if you need me to explain more thoroughly just let me know!
    -Gyro
    Pleasanton, CA
    5,722
    Welcome to the forum Gyro!
    I will answer one of your questions. Yes, it is not unusual for the indicator bulbs to burn. I had to replace a number of mine several times on my 2005 before I replaced them with LED's.
    Checking these bulbs is super easy. The plastic housing which covers these bulbs is held on with two screws. These screws are very small and easy to lose, so be careful not to drop these. Just loosen both screws and try to pull the housing and screws off together. With the cover off, check to see if these lights are working. If not, the indicator bulbs can then be removed by pushing down and turning them counterclockwise. Then you can check the filament to see if it is broken or you can use a continuity tester. If your high beam indicator or turn signal bulb works but not your neutral light, then move one of the working bulbs into the neutral light socket. If it still doesn't work, then the problem is something other than just the bulb.
    I hope this helps,
    Brian
    littletommy and jbfla like this.
    Junior Member Gyroshark's Avatar
    Dec 2014
    I hope this helps,
    Brian
    I thought the issue was a lot deeper than this however you were right! It was just the bulbs. My next question would be where exactly to get these and what the part number would be for them. As well as do they make these in LED form? I have a feeling LED's would last a lot longer. Thanks again!
    -Gyro
    TW-Brian likes this.
    Jul 2012
    Wet-ern Washington
    1,409
    - Leisure Time Larry -
    Sep 2012
    Wichita, KS
    1,868
    Your high idle happening "on occasion" could be as simple as the throttle cable needing lubed. Or maybe the cable housing is slipping out of its location and not allowing the slide to spring back into its idle spot. Hope this helps, and your cure is simple.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
  1. Neutral light not coming on all the time.
    By old mad max in forum Technical Help
    Last Post: 08-10-2014, 09:45 PM
  2. Neutral or 1st at red light ?
    By willinbc in forum General Discussion
    Last Post: 08-10-2012, 07:37 AM
  3. Neutral Light and shifting / engine questions
    By TWBUSHMAN in forum Technical Help
    Last Post: 07-10-2012, 06:39 AM
  4. Will this brake light flasher work?
    By chevyy1212 in forum Technical Help
    Last Post: 01-22-2012, 10:27 AM
  5. Wanted - Speedometer and neutral light cover
    By cohassetsteve in forum TW200 Classifieds
    Last Post: 04-25-2011, 08:22 PM
Tags for this Thread
