Pilot screw cap on 98 how thick is cap?
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Purple
Thread: Pilot screw cap on 98 how thick is cap?
    Member DANo896's Avatar
    Feb 2012
    Wenatchee
    30
    I want to drill out screw the cap. just like an idea how far to go down with bit. thanks
    Pleasanton, CA
    5,720
    This is just a guess, but I would say less than 1/16".
    Don't try to drill the plug out. Just enlarge the hole enough to get a sharp pointed (i.e. drywall) screw started, then use the screw to gently wiggle and pull the plug out.
    Mar 2015
    Ynys Môn
    4,571
    Just enough to get a grip with a screw - don't over-do it
    jeffrolives likes this.
    - Hidden Content
    Senior Member jeffrolives's Avatar
    May 2015
    NW Iowa
    343
    1/4"
    It is just a brass plug.
    The bit goes through it pretty good and quick. I just did mine with a cordless, on slow, and no stop. Light pressure. As soon as through, stop going in.
    Insert drywall screw and wiggle/pull out.
    Done.
    Feb 2012
    Wenatchee
    30
    Thanks
  1. Has anyone tried this pilot screw?
    By Bigred21001 in forum Technical Help
    Last Post: 10-13-2014, 02:02 PM
  2. Pilot Screw Adjustment Help
    By bodhi4 in forum Performance and Customization
    Last Post: 03-22-2013, 02:33 PM
  3. Pilot screw set
    By dantilghman1 in forum Technical Help
    Last Post: 01-25-2013, 11:05 AM
  4. pilot/air screw
    By PalmStateCrawler in forum Technical Help
    Last Post: 06-04-2012, 08:27 AM
  5. Pilot Jet Screw Closed
    By JD_ in forum Technical Help
    Last Post: 04-11-2012, 08:32 AM
