Carb Problem
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By Purple
Thread: Carb Problem
    Junior Member Maulepilot's Avatar
    Jul 2015
    Corsicana, Texas
    4
    Carb Problem
    Just bought a 2001 TW 200 from a friend. it has 155 miles on it and looks like new, only covered in dust from sitting.
    It was last running about 3 years ago. Put new fuel in and got it started but it ran kind of rough. Pulled carb, cleaned jets,
    and needle/seat. removed venture needle and cleaned. When I put it back together, it started and ran better, but when it idles
    down it floods and dies. Tried adjusting mixture, but has no effect. When I try to restart it it just chugs and won't take fuel (flooding).
    If it sits for about thirty minutes, it will crank up and run if you keep it revved up, but will flood and die if you let off the gas.
    I didn't mess with the float setting...it seems to be right. I wonder if I didn't put something back correctly related to the vacuum diafram?
    It seems maybe it's not getting enough air? Anybody have ideas?
    Thanks,
    Sep 2012
    Wichita, KS
    1,868
    I'm not the one to answer this, but it sounds like the float is sticking, not shutting off fuel/overfilling the float bowl. Others on here will give better help. Best of luck, you'll get it.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    Mar 2015
    Ynys Môn
    4,571
    Take a look at the air filter
    These bikes have a rather "frugal" carb - and as such, its often the first thing to go for
    But as its been standing for a while, consider the air filter as part of the carburetor - check it first, as it's easier to get at and simpler to fix. If you need any help with the air filter just shout and we'll talk you through it ...........
    admiral likes this.
    - Hidden Content
    Jul 2015
    Corsicana, Texas
    4
    Thanks guys!! Think I've found the problem. It seems that when I was blowing carb cleaner off the carb body, I blew the needle valve seat out of the body. Found it on the floor luckily.
    Haven't put it back together, but that should explain the flooding?
    Jul 2015
    Corsicana, Texas
    4
    Thanks for the info Purple...what is the trick on the air filter box? The filter was fried also. I've ordered another one.
    I had to loosen all of the bolts on the box and push it down in the frame to get the filter out. Is that the best way to do it?
    Jul 2015
    Corsicana, Texas
    4
    Mar 2015
    Ynys Môn
    4,571
    The air filter should be foam, with enough oil on it to make it sticky, without being able to "squeeze" any out - which means grab hold of the sucker, soak it in something like S.A.E.30 - then wring it out till it hasn't got anything left to give - then shove it back in there
    The resulting mess will then be "sticky" enough to filter out finer particles, but more importantly, provide just enough resistance to air flow to allow your carb to work correctly.
    An old neglected filter is likely to have gummed up, causing the carb to flood, particularly at idle
    How you get thing in and out is up to you, your sense of determination, and the state the bike is in ........
    - Hidden Content
    18,702
    " I had to loosen all of the bolts on the box and push it down in the frame to get the filter out. Is that the best way to do it?" -huh? If your 2001 TW is stock then simply remove two securing screws and pull off left side plastic, then remove 4 screws holding air filter box cover on. Remove this cover now and filter and it's plastic "cage" should pop out with the cover without any clearance issues.
    If you or others don't already have it there is a downloadable manual, it really helps explain a lot of maintain ace and repair issues.. Can someone find the link and post it for Maulepilot and others?
    18,702
    Service manual:TW200mainmanual.pdf (44.77 M
    Supplement for "01 and newer TWs:'01 and newer supplement.pdf (3.26 M
    Parts catalog ( many other options...Boats.net or Stadium Yamaha for example) : http://www.yamaha-mo...-Off&mode=TW200
  1. 87 TW carb problems? Electical problem?
    Last Post: 02-22-2014, 04:31 PM
  2. Carb Problem
    By mogcamper in forum Technical Help
    Last Post: 01-18-2013, 06:53 PM
  3. problem starting battery or carb ? maybe spark?
    By dubstep in forum Technical Help
    Last Post: 06-12-2012, 08:06 AM
  4. Carb problem, I think?
    By surfmansd in forum Technical Help
    Last Post: 02-19-2012, 09:07 AM
  5. Carb problem
    By assquatch20 in forum Technical Help
    Last Post: 09-24-2010, 12:53 PM
