Rear Tire off...won't go back home
Results 1 to 8 of 8
Like Tree8Likes
  • 2 Post By jtomelliott49
  • 4 Post By Megawisdumb
  • 2 Post By Megawisdumb
Thread: Rear Tire off...won't go back home
    Junior Member Megawisdumb's Avatar
    Jun 2013
    Alabama
    10
    Broke a chain last week on my 2006 so thought I would replace it and sprockets and brakes. All was well until I went to slide back in the rear tire and the fargn thing won't slide back on. It's almost like its 1/16th too long. I went back a compared my brake shows and they are the same width and the cap seems to fit on the drum about the same. The sprocket side axle plug just seems too long. Played with it til dark and bailed until later today. Anyone encounter this issue?
    Sep 2012
    Wichita, KS
    1,868
    Yes. Took me a long time to get spacers and all to slide into place. It'll go.....you have to have wheel perfectly vertical/bike vertical, hold your mouth just right. You'll get it.
    Peterb and GTG like this.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    Mar 2015
    Ynys Môn
    4,571
    Wait till you try the front ........
    - Hidden Content
    Jun 2013
    Alabama
    10
    Thanks folks!! She's on. Never underestimate the value of a good nights sleep and a cold beer!
    dette, TopPredator, LuvNot and 1 others like this.
    Sep 2012
    Wichita, KS
    1,868
    Just one cold beer??? That wouldn't be enough for me. Gotta have at least TWO. And, glad you got it together. So the front is harder than the back??? I'm dreading that. Fighting a front tire replacement, then pinched tube, then a couple months rest and several thirty packs. Good thing I have a spare set of wheels so I can take my time.
    Tom in Wichita
    87 Yamaha TW200
    99 Yamaha TW200
    Jun 2013
    Alabama
    10
    I'm not planning to pull the tire to replace the pads. I replaced a front tire on my ttr last year and it was actually very easy. In Alabama, a beer can refer to a single bottle or a case or a keg for that matter. If I mislead anyone into thinking it was a solo beverage, you have my sincere apologies.
    goldenhtr and Dryden-Tdub like this.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,482
    I went to put my rear wheel back on today after replacing the wheel bearings and it was to narrow for the swing arm. When I knocked the wheel bearings out I never noticed that there are two 6203 bearings on the sprocket side of the wheel (yes my work bench is full of junk)
    Mar 2015
    Ynys Môn
    4,571
    The drum front is a PITA - but at least the wheel is lighter
    - Hidden Content
  1. FS: CO - Shinko SR244 front tire and Bridgestone TW34 rear tire
    By Nicholast in forum TW200 Classifieds
    Last Post: 12-06-2014, 10:02 PM
  2. Replies: 13
    Last Post: 09-14-2014, 10:36 AM
  3. rear tire change...surface rust...tire lube?
    By blackmouthcur in forum Technical Help
    Last Post: 04-13-2014, 09:53 AM
  4. Ride report, short camping trip Muscatine-Galena-Prarie Du Chein- Elkader-and back Home
    By iowatdub in forum Trails, Off-road, and Adventure Riding
    Last Post: 06-04-2013, 07:22 PM
  5. Home built rear rack
    By glas482 in forum Performance and Customization
    Last Post: 11-01-2010, 08:47 PM
