Please help Tdub only starts with clutch in no
Results 1 to 3 of 3
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    My wifes 89 tdub won't start in neutral all the sudden. When its in neutral the Green neutral light won't come on. I know it's in neutral and the bulb is good. The starter won't do anything unless I pull the clutch in. Anybody know what to chec? Thanks so much
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Sounds like the neutral safety switch. I'll defer to the service manual for troubleshooting.
    Jan 2014
    New Jersey
    592
    If I jiggle the shifter neutral light comes on bike starts. I ordered the switch,it's under the cover on the sifter side.
  1. Only starts in neutral
    By alhunter in forum Technical Help
    Last Post: 05-18-2015, 07:30 AM
  2. Starts different, Elec vs Kick
    By rivershot in forum Technical Help
    Last Post: 12-18-2014, 05:40 PM
  3. Starts on choke then dies ???
    By Jhlebain in forum Technical Help
    Last Post: 10-09-2014, 07:11 PM
  4. electrical help, Push Starts only
    By iowatdub in forum Technical Help
    Last Post: 06-04-2013, 07:26 PM
  5. Second gear starts
    By Hobopoet in forum Performance and Customization
    Last Post: 03-19-2011, 04:43 PM
