87 is all fixed up- im a happy camper
Results 1 to 4 of 4
    540
    HI,
    My 87 now runs like new, if not better. Always started and idled very well, but there seem to be a mis at half throttle under acceleration.
    to make a long story short I got a keyster carb kit, took off the carb, rebuilt it and bingo. Runs strong and no miss, yehaw.
    866
    Cool. Sounds like you've got it dialed in.
    Member SURVEYWATERS's Avatar
    Jan 2012
    Cayce, SC
    71
    What did you set the clip on the new needle to demarko69? I just installed the Keyster kit and I'm having some real problems. The bike ran fine before the kit but the float needle was shot. I bought the kit and have since also purchased a #40 pilot since the kit comes w/ a #38. It runs on choke but not well and when the choke is removeed there is a backfire through the carb. It also slowly returns to idle when rev'd rather than a quick drop. I thought it may be an air leak so I replaced the intake manifold, didn't help. I am wondering now if it's running rich and needs the needle lowered.
    2005 roadstar,2001 drz400s,2000 xr70,1999 z50r,1987 lt80,1986 vt1100c,1982 xr250r, 1974 xl125, 1972 sl125
    Senior Member TeeDubs's Avatar
    Aug 2011
    Wisconsin
    423
    Hey demarko69 I just picked up an 87 and I can't even get it to run... did you have any issues with the starter button not working? Whoever owned it before me thought it would be a good idea to weld the hole kickstarter shut :/
    I started a post here if you have any advice or could check out my thread
    1987 TW200 - Work in Progress
    1995 TW200 - Blaster Shock
    2007 DRZ400sm - Stock
  1. Clutch fixed, now Kickstart problems!
    By SCARE! in forum Technical Help
    Last Post: 08-30-2012, 04:23 PM
  2. Happy new year
    By rmcglad55 in forum Off-Topic
    Last Post: 01-01-2012, 04:42 PM
  3. happy birthday
    By desertdog in forum Off-Topic
    Last Post: 08-22-2011, 09:11 PM
  4. Miss, Backfire, Hesitation ***Fixed!***
    By pantera1 in forum Technical Help
    Last Post: 06-16-2011, 04:50 AM
  5. Best bike for back of camper
    By HiCap in forum General Discussion
    Last Post: 04-24-2011, 07:07 PM
cool camper fix up
