why is my 87tw braiking spokes?????
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By ejfranz
Thread: why is my 87tw braiking spokes?????
    Senior Member 66roadkill66's Avatar
    Oct 2013
    roseburg oregon
    312
    some time ago my tw broke a long spoke on the rear, and now I find 3 broken long spokes in the rear wtf??? I do not abuse this rig at all, some light off road use and mostly back and forth to work, it has around 4300 miles now, anybody else running into this problem?
    87tw,08 klr650,00dr200,76tl250,73cl175 scrambler,75tl250,76tl125,1960 cushman trailster,
    Feb 2015
    Maple Ridge, BC, Canada
    1,545
    I have only had one spoke on all my bikes ever break and it was do to me not checking the tightness.
    Spokes break if the spokes are not of even tension. Check for loose spokes, some spokes may also be over tightened.
    66roadkill66 likes this.
    Oct 2013
    roseburg oregon
    312
    I think I will take it to my local bike shop and have my buddy take a look at it you may be right, they have seemed ok when I checked them in the past but I have no idea what the correct tension is.
    Hailey, ID
    3,340
    Quote Originally Posted by 66roadkill66 View Post
    .....but I have no idea what the correct tension is.
    The correct tension is whatever makes the wheel round and run true. If your buddy has experience in wheel truing, best take it to him. There IS a general range of tensions in a properly trued wheel, but if it is not bent, no spokes should be loose to the point of sounding a very dull clunk instead of a ring when struck with a screwdriver.
    In a TW that old, the spokes could also be corroded and/or weakened by previous owner's abuse.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Rear spokes
    By brushhippie in forum Technical Help
    Last Post: 08-02-2015, 09:40 AM
  2. Want to buy right side cover for 87TW
    By jtomelliott49 in forum TW200 Classifieds
    Last Post: 08-04-2014, 07:06 PM
  3. I need a rear spoke for my 87tw
    By 66roadkill66 in forum Technical Help
    Last Post: 02-25-2014, 07:13 PM
  4. need a rear long spoke for my 87tw
    By 66roadkill66 in forum TW200 Classifieds
    Last Post: 02-25-2014, 05:56 PM
  5. Help, Spokes, Help!
    By retro in forum Technical Help
    Last Post: 10-13-2011, 09:54 AM
