Rings screeching...3 week old bike?
Page 1 of 10 123 ... LastLast
Results 1 to 10 of 93
Like Tree212Likes
Thread: Rings screeching...3 week old bike?
    Jun 2015
    Nova Scotia
    1,394
    Just thought I'd share this as an example of what can happen.
    3 Weeks and 400 km of mindful break in driving and nothing more then half throttle. I did an oil/filter change which was good for an hour or so of putting around.........So we start out on a long journey (of course) and a 1/4 way out I start hearing and feeling an intermittent awful screech. I pull over and have look thinking it's the front brake. Looked fine so I started it up and it was good for the first few seconds. Then it went really bad at which point it was obviously the piston rings. I put it in neutral and got a tow from an ATV (scarey). We got it home and checked over the oil situation and all looked good. It seems like an unlucky and unavoidable situation.
    The dealer is picking it up and it should be covered under warranty but talk about bad luck being midsummer and we were planning a camping trip within the next few weeks......
    Frosty Hollow
    13,044
    Sorry to hear about this. I recently performed an oil change on my 2015 and all is well.
    Couple curious questions. Did you replace the oil filter or clean it? Did you "bleed" the oil from the oil check screw? Some folks swear bleeding the oil isn't necessary, though I always do.
    When checked, can you tell us what the dealer said was causing the screeching?
    Thanks, and hope they can fix or replace as necessary.
    Fred, dabsdog, fishguy and 2 others like this.
    Jun 2015
    Nova Scotia
    1,394
    Well I took off the big drain bolt and the top refill cap. Rocked and tipped all that I could to get it all out. Replaced the filter with a new one the dealer supplied. I even checked/ cleaned the screen from the drain hole. On the first oil change there were some grindings but what I suspect as a reasonable amount for break in. After screeching I changed the oil again to check the filters and no additional grindings were visible. I did exactly what the manual says...must be a coincidence that this happened after an oil change.
    I'll keep ya up to date. The dealer made a big deal about getting me back on the road asap so I'm guessing it's somewhat a priority due to how new it is.
    Sep 2012
    Northwestern Oregon
    1,092
    That is too bad. My condolences.
    What kind of oil filter did you put in? Was it the "4 hole" type? It should look like this (photo belongs to member "Indiana")...
    Jun 2015
    Nova Scotia
    1,394
    I'm not sure. The dealer sold me the filter. When I checked it after the screeching it was ginding free with plenty of oil in it.
    Spokane, Washington
    17,283
    I bet they gave you the wrong filter. One with only 2 holes rather than the 4 needed. So, it's burning up the top end of the engine.
    Fred, fishguy, WECSOG and 1 others like this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member dabsdog's Avatar
    Jun 2014
    Painted Post ny
    129
    Removing the oil check screw (motor running) lets you see if oil is getting to the top end and should be done every oil change like you recommend.
    littletommy and fishguy like this.
    18,710
    Using the "bleed screw" above the oil filter confirms that there is oil flow through the filter to the valve train. Littletommy might be right. The dealer's big deal about getting you back on the road a.s.a.p. might be due to concern that their service tech may have installed wrong filter. Like a doctor they might prefer to quickly bury their mistakes.
    Feb 2013
    Missoula, MT
    908
    1) Dealers have sold the improper oil filter in the past. It must be in stock for some other bike.
    2) Always check for oil flow with the "check bolt". It makes a mess but saves top ends.
    3) Sometimes this happens during break-in for almost no discernible reason. The reason it happened to me was that the shop that rebuilt the top end on my 1995 TW were idiots (no longer in business). I rebuilt it myself the next time and found ALL their errors.
    littletommy, TWilight and kj7687 like this.
    Feb 2013
    Missoula, MT
    908
    Yep. That's it!
    littletommy likes this.
  1. Four corners bike week?
    By ZDR1 in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-05-2014, 07:59 PM
  2. New 2014 at Daytona Bike Week
    By FootDoc in forum General Discussion
    Last Post: 03-22-2014, 04:12 PM
  3. A Slice of Bike Week 2011
    By jbfla in forum Off-Topic
    Last Post: 03-18-2011, 09:33 AM
  4. Daytona Bike Week Dual Sport / Adventure Ride
    By CaptD in forum Trails, Off-road, and Adventure Riding
    Last Post: 03-03-2011, 11:39 PM
  5. Not another Newbie's first week on bike...
    By harleyjoe43 in forum General Discussion
    Last Post: 11-27-2010, 03:51 AM
