High Idle Question
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By scotti158
Thread: High Idle Question
    Junior Member Bentzra's Avatar
    Apr 2014
    Syracuse, NY
    12
    High Idle Question
    Hi all,
    Been loving my little old (92) TW. The other day it was running funny (died on me 2x) and now it runs like the choke is always on (its not). I pulled the carb apart and cleaned the jets, cleaned the air filter but the bike just runs at a high idle about like the choke always being on. Any thoughts on what to look ant or check next?
    Thanks
    May 2013
    Groton, NY
    2,663
    Maybe an intake leak. Try sqirting a little WD-40 or something similar on the boot between the carb and head. If engine speed changes. there is a leak.
    Leisure Time Larry likes this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Apr 2014
    Syracuse, NY
    12
    Good idea - I'll check that - thanks
    Senior Member will's Avatar
    Jun 2015
    119
    Starting fluid works much better. The change in the engine will be more noticeable and easier to detect if there is a leak in the boot.
    Mar 2015
    Ynys Môn
    4,571
    I’d always thought the choke worked the opposite way – restricting air flow - (try the air filter)……
    - Hidden Content
  1. Replies: 12
    Last Post: 02-04-2015, 09:34 AM
  2. High idle after first ride....
    By nunya in forum Technical Help
    Last Post: 09-14-2014, 07:52 PM
  3. idle to high with choke on
    By saabbug in forum Technical Help
    Last Post: 03-06-2014, 07:14 PM
  4. High Idle - Hot Engine
    By Avi Kwame in forum Technical Help
    Last Post: 03-31-2013, 06:57 PM
  5. High Idle
    By Henrici in forum Technical Help
    Last Post: 01-28-2011, 01:25 PM
