Who has the parts list?
Results 1 to 10 of 15
Like Tree11Likes
Thread: Who has the parts list?
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,169
    I am trying to figure out all the parts necessary to make up a kick starter kit. Some say that Yamaha discontinued selling the parts in a kit form but all the parts should be available in separate form if I can find the list. I think the kits came with all the part numbers listed in the instruction sheet.
    If anyone has the numbers can you post them here?
    Thanks
    1987 Yamaha BW350 Big Wheel
    Senior Member wrench-puller's Avatar
    Ladysmith, B.C.
    548
    littletommy likes this.
    2009 TW200, Jimbo shield, 47&55T rear with DID chain, Maxxis Ceros Rear, Kendra 270 front, extended swing arm, 1"Risers, Rear rack, Raised front fender, XOG GPS.
    Jun 2013
    Forestburgh, NY
    8,169
    Quote Originally Posted by wrench-puller View Post
    Yup, those are all the parts of the entire assembly some of which are already there in a stock bike that never had a kicker. This is what I am trying to figure out, Just what parts that I need to buy so I can install the kicker.
    Stanwood,Wa
    1,903
    Gary I found this on the old TW site,
    From Frank Colver
    Actually I have no interest in the clutch kit since I'm done with my conversions. It sounds like it is cheaper than ordering individual parts from Yamaha and anyone thinking about adding a kick start should certainly look into it. If one looks at Yamaha's assembly drawing, on their parts web site, it looks like one would need some very expensive parts that are actually already in the bike. I'm just trying to be helpful by providing information to anyone buying the parts individually so that they don't make an expensive mistake.
    CORRECTED KICK START PARTS LIST,
    REQUIRED TO ADD STARTER TO LATE TW200
    1 15A-15660-01-00 KICK AXLE ASSY 12 90468-26122-00 CLIP 1
    3 401-15676-00-00 COVER, SPRING 1
    4 15A-15666-00-00 SPACER 1
    5 90508-26538-00 SPRING, TORSION 1
    6 99009-17400-00 CIRCLIP 1
    7 90201-175F6-00 WASHER, PLATE 1
    8 36X-15641-00-00 GEAR, KICK 1
    9 90209-17226-00 WASHER 1
    10 93102-17263-00 OIL SEAL 1
    11 90201-173F4-00 WASHER, PLATE 1
    12 15A-15651-01-00 GEAR, KICK IDLE (28T) 1
    13 90214-17028-00 WASHER, CLAW 1
    14 N/A CIRCLIP, use the two that are already on the shaft
    after removing the spacer that will be replaced by the gear. 2
    15 54G-15620-00-00 KICK CRANK ASSY 1
    16 54G-15621-00-00 BOSS, KICK CRANK 1
    17 90501-12081-00 SPRING, COMPRESSION 1
    18 93507-32009-00 BALL 1
    19 90152-06010-00 SCREW, COUNTERSUNK 1
    20 90338-18014-00 PLUG 1
    21 97027-08030-00 BOLT 1
    4BE-15462-00-00 GASKET 1
    Item nos. refer to Yamaha’s assembly drawing; 3AW7171-0120 1
    The drawing can be found on Yamaha's parts web site and should be used during
    assembly.
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Jun 2013
    Forestburgh, NY
    8,169
    Quote Originally Posted by goldenhtr View Post
    assembly.
    That is Golden, pun intended!
    Thank you.
    Pleasanton, CA
    5,820
    From Frank Colver
    assembly.
    I would also add the lock washer that secures the clutch basket.
    (I am too lazy to look up the number for that bum GaryL !)
    PlacerLode likes this.
    Jun 2013
    Forestburgh, NY
    8,169
    Ha! We have both been called much worse and I am a proud MC Bum!
    I don't honestly understand the Clutch kit comment and it possibly being cheaper?
    TW-Brian likes this.
    Pleasanton, CA
    5,820
    I am not sure what that comment refers to either.
    Here is the part that I am referring to. Since you have to remove the clutch assembly in order to install the idler gear, you will probably break off one of the locking ears. If your clutch has already been removed once before, you may not have any locking ears left and will have to order a new lock washer before you can continue the kicker installation. I am pretty sure that the Yamaha kits include a new lock washer for this reason.
    I am still not gonna look that number up for you !
    Jun 2013
    Forestburgh, NY
    8,169
    I hate those lock rings that are guaranteed to break! I buy new ones with every rear sprocket I replace.
    Just because you won't look up that part for me I am tossing a bunch or rotten Empire State Apples at you and I bet Dryden will join this effort to bombard the Left coast!
    Thanks Brian and Goldenhtr for the great info. I will post if my parts guy can make up kits from the separate parts list at a reasonable price point. Dam this getting old really does suck! I can't remember who I sold my last kick kit too here for $200 but wish I never had sold it. I just keep thinking, this will be the last TW I buy, fix up and flip and then another one falls into my garage. I did kind of fall in love with the XT225 I got with the last TW deal and neither one has a kicker being 2006 models and both with under 100 miles on them. Being just a part time and very local rider I honestly don't need a kicker but my wrenches are calling me to get off my ass and to some fun work.
    littletommy, TW-Brian and admiral like this.
    Stanwood,Wa
    1,903
    Not sure either about the clutch kit referance but you can read the whole thread here.
    corrected kick start parts list - Yamaha TW200 Trailway Discussion Forum
    Gen:27:3
    -Ronald Reagan
  1. Replies: 83
    Last Post: 02-02-2018, 11:05 AM
  2. Moab Spare Parts List
    By Mel in forum General Discussion
    Last Post: 03-18-2015, 02:43 PM
  3. Replies: 0
    Last Post: 12-16-2012, 01:03 PM
  4. TW goodies wish list.
    By lizrdbrth in forum Off-Topic
    Last Post: 08-24-2012, 10:00 PM
  5. base gasket parts list
    By dganey in forum Technical Help
    Last Post: 05-16-2011, 02:55 PM
