Another LED Flasher question
Results 1 to 10 of 18
Like Tree7Likes
Thread: Another LED Flasher question
    Junior Member andrew5336's Avatar
    Jun 2015
    Durban, South Africa
    16
    Hi All
    DISCLAIMER - I HAVE THE MECHANICAL AND ELECTRICAL KNOW HOW OF A MOOSE.11705459_10153375088160733_4500426094600556872_o.jpgIMG_2156.JPG
    I changed the indicators on my 2015 TW to smaller LED units.
    Initially I did just the back ones (along with the stop lamp) and when indicating it would flash faster than normal but still flash.
    I then replaced the front ones too and tried them to see what happened with the standard relay.
    When indicating, the flashers just go on - no flashing.
    1) Is the indicator relay on the right hand side sort of where your knee would go? I replaced this with a special LED relay but still no luck - lights just go on with no flashing.
    Do I need more or less resistance on the relay (if the thing I changed is indeed the relay!).
    2) The blue wire going to the front flashers that causes them to stay on permanently - can I just isolate that or is it integral to the front flasher's operation? It is not a legal requirement in South Africa to have the front flasher light lit up when no indicating as I believe it is in the USA.
    Thanks in advance for any help - before and afters as above.
    Jun 2015
    16
    Round relay the new one, square one the original.
    Mar 2015
    Ynys Môn
    4,571
    The newer (post 2000) TW’s use a system that involves “position” lights — dual filament indicator bulbs — constantly on. So that “blue wire” is probably confusing the flasher unit — (I have no idea what colour the wire is, but if you’re sure, isolate it). You should probably swap out the dash bulb for an LED while you’re at it — not sure if this would contribute to the cause of your problem, but an LED bulb in there is “belt and braces”.
    Try this first and see how you get on ……..
    - Hidden Content
    Spokane, Washington
    17,289
    Yamaha TW200 Parts and Performance - ProCycle
    If you look at this website, under the lighting and electrical section, you will find 3 items. The LED turn signal resister kit, the LED 12 volt turn signal flasher and the LED signal diode kit. I think if you look at these and read the "more info" and "installation" information given on these items, you will find your answer. Hope this helps, keep us posted please.
    troll likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2014
    Bel Air Maryland
    4,169
    Sorry to high jack but I had never heard the term "belt and braces". used before. Learned something new this morning.
    Belt and braces
    Meaning
    Careful - not taking any chances.
    Origin
    Belts and braces (a.k.a. bracers) are meant to hold one's trousers up. Going 'belt and braces' is a double insurance against having them fall down. The figurative use, as a general term for cautiousness, was coined around the mid-20th century.
    In the USA 'belt and suspenders' is used with just the same meaning. That emerged at around the same time too. The first citation in print we have is from the Galveston Daily News, 1935 - in their 'News Behind the News' column:
    "A pessimist wears both belt and suspenders."
    Jun 2015
    16
    Thanks very much.
    Those resistors - where does one wire them in? I can get resistors from my local electronics shop. I thought that one would need one on each indicator but I see on the kit that there are only two for 4 indicators?
    Spokane, Washington
    17,289
    I am not sure. It may be because the front signal lights stay on all the time and the rear ones don't. Did you read this part on the procycle site?
    *Unfortunately the TW200 turn signal circuit is wired differently than most other motorcycles.
    You can indeed make everything work you just need to do a little extra wiring. Cap off the wires that come from the motorcycle to the indicator bulb, you will no longer use those two wires.
    You need to run a wire from +12volt side of left front turn signal bulb to one of the Red wires if the diode kit.
    Then you need to run a wire from the +12volt side of the right front turn signal bulb to the other Red wire of the diode kit.
    Then hook the White wire of the diode kit to one wire of the indicator bulb. Then hook the other wire of the indicator bulb to ground.
    1st John 1:9
    John 3:16
    John 3:17
    Jun 2015
    16
    Wow.
    Beyond me.
    Auto electrician here I come!
    Spokane, Washington
    17,289
    Quote Originally Posted by andrew5336 View Post
    Wow.
    Beyond me.
    Don't do it yet, wait around, someone will come along to help hopefully. Can anyone help this gentleman please?
    1st John 1:9
    John 3:16
    John 3:17
    Mar 2015
    Ynys Môn
    4,571
    Tommy - I think those resistors are for use with LED lights and the original flasher unit - with the new flasher unit in place he should be well withing range .......
    littletommy likes this.
    - Hidden Content
  1. wtb: 89 flasher relay...anyone have one to sell?
    By twbeagle in forum TW200 Classifieds
    Last Post: 11-10-2014, 10:32 AM
  2. Please help with flasher problem
    By Holdnon72 in forum Technical Help
    Last Post: 08-14-2014, 09:55 AM
  3. Melted flasher relay....
    By rbm in forum TW200 Classifieds
    Last Post: 04-04-2013, 06:58 PM
  4. Flasher relay ID
    By chevyy1212 in forum General Discussion
    Last Post: 04-01-2012, 10:16 AM
  5. Led flasher
    By Paulp1 in forum Technical Help
    Last Post: 02-21-2012, 04:15 PM
