Headlight bulb question
Results 1 to 5 of 5
    Senior Member darnold87's Avatar
    Salem, OR
    908
    So I was changing out my headlight bulb and noticed the one I took out is a 55watt rather than the OEM 35watt. (bulb part# 64185, which is an H-4 bulb)
    Can anyone tell me if this is a bad thing (on the charging system)?
    I keep a tender on the battery at all times but noticed after a full days ride, my battery is not fully charged like I'd expect... and the battery is less than a year old.
    Any thoughts?
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member HenryJ's Avatar
    Oregon, USA
    184
    I'm running a 130/90w with no problems in my 2006 TW200. The older bikes had a smaller charging system output. If you are having problems, perhaps drop back to 35W and see if there is an improvement?
    Personally, I think the difference will be minimal and a non-issue.
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
    Ephrata, WA
    1,125
    I switched to a the higher wattage bulb last year and now my battery is completely dead. The battery is about four years old. Don't know if the bulb zapped the battery, or the battery's life has expired. I love having more light on the bike while riding to work in the morning.
    1990 TW200
    jim
    jim is offline
    Senior Member jim's Avatar
    Indio, CA
    100
    I think 4 years on a regular battery is good
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    Ephrata, WA
    1,125
    Quote Originally Posted by jim View Post
    Thats kind of what I thought too.
    1990 TW200
  1. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 01:32 AM
  2. 1990 headlight question
    By Bizz in forum Technical Help
    Last Post: 06-19-2013, 10:55 PM
  3. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
  4. Quest for a brighter headlight with stock fixture / DOT bulb
    By praeses in forum Performance and Customization
    Last Post: 08-12-2011, 10:14 AM
  5. H4 bulb question / What headlight setup do you have
    By chines75 in forum Technical Help
    Last Post: 05-24-2011, 04:02 AM
