"91" tw200 wont start,like it cranks then tries to fire backwards??
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree4Likes
Thread: "91" tw200 wont start,like it cranks then tries to fire backwards??
    Junior Member waggy's Avatar
    Aug 2015
    14
    Hi all. i bought a project tw for the misses but cannot get the friggen thing running. it had been sitting a year or 2 and had a rusty tank.
    i have serviced it checked timing and valve clearance new spark plug,pulled carby apart 5 times. but still wont run. it used to wind over and when it fired it looked as if it tried to turn the engine the wrong way and smoke out the carby??and felt like it was doing the same thing with the kick starter. can any one help?? this thing has got me beat..
    Aug 2015
    14
    its like the timing is way to far advanced ,but the timing marks line up spot on??
    Mar 2015
    Ynys Môn
    4,684
    An early example of a reverse function on the TW ……… (kidding) …..
    Here are the manuals - https://tw200forum.com/forum/technica...r-manuals.html - worth downloading for reference
    Just a “stab in the dark” — but could it be 180 degrees out ? — don’t even know if that’s possible on a TW — but it would explain “confused combustion” …………
    Did the previous owner have it apart at any stage ?
    Welcome to the mad house — (we’ll help you all we can) …….
    - Hidden Content
    Aug 2015
    14
    thanks for the welcome, i rang the last owner hopeing he could save me some time. the said it was running then went in the shed (2 years ago).. so i dont know. but i have a sore leg from kicking it and think the starter bush must be worn now because it makes bad noises from below when hitting the button now, and it wasent for the last month of trouble shooting..think ive worn it out..
    jeffrolives likes this.
    Mar 2015
    Ynys Môn
    4,684
    "If" it was running the last time he parked it up - the only way it will "fart" from the carb is excess fuel
    The carb "might" be letting fuel through without even turning over the engine - we've had that a couple of times on here
    Typical symptoms of this are rising oil levels - so check the window in the side of the crankcase - I turn the fuel off when not in use, suggest you start doing the same. With the fuel in the "off" position, try starting it up - it should run on the contents of the float bowl, but check the oil level first
    If the tank was rusty, it might be a good call to put an in-line filter between the tank and the carb, or you risk being back at square one
    How much did you pay for this thing ? - and how much effort are you prepared to put into it to get it running ?
    - Hidden Content
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    742
    Could you take a picture of the CDI and post it here? It's under the right side cover.
    '87 TW200
    '94 Sportster 1200
    '74 XL70 Frankenbike
    '76 CT90
    '72 CT70
    '72 XL250
    Aug 2015
    14
    yes starting to think the carb might even be missing a small part or 2. might order a carb kit.Bike has cost me 1000 bucks. dont think i will be putting much more into it.
    Aug 2015
    14
    Quote Originally Posted by WECSOG View Post
    will do wont be for 3 days thoe as im away at work
    Jun 2015
    742
    Ok, I'll be watching for it. Don't give up on it. There are people on this forum who can help you troubleshoot and get it running right.
    '87 TW200
    '94 Sportster 1200
    '76 CT90
    '72 CT70
    '72 XL250
    19,184
    WECSOG, do you want waggy to look at bottom side of CDI for scorch marks, or other signs of overheating/ shorting?
  1. Warren, NH "Old Home Days" aka "Vernstock"
    By SickPuppy76 in forum Trails, Off-road, and Adventure Riding
    Last Post: 04-03-2015, 10:05 AM
  2. "Bombs Away", or "A Video For Indiana"
    By Fred in forum Off-Topic
    Last Post: 11-01-2014, 10:21 PM
  3. TW200 video - Cave along "Chesleys's Challenge"..
    By Scotts in forum Trails, Off-road, and Adventure Riding
    Last Post: 09-09-2014, 05:32 PM
  4. How do you find the build date of a TW200? Negotiating a "new" bike...
    By RiskEverything in forum General Discussion
    Last Post: 03-03-2014, 08:59 AM
  5. DG "O" Series Slip-On Exhaust with 1" Quiet Core Silencer
    By wiso2 in forum TW200 Classifieds
    Last Post: 07-08-2013, 11:31 AM
