Source Coil Wiring to CDI - GY6 CDI Troubles
Results 1 to 3 of 3
    Junior Member Oleschool's Avatar
    Jul 2012
    22
    I recently replaced my cdi with an aftermarket GY6 cdi. The only thing is I can't seem to figure where the yellow wire should connect to now that the new CDI only has 6 wires versus the old ones 10 wires.The bike starts and runs but I need to find out what effect having this disconnected is going to have on the bike.There is voltage on it when the bike idles and as you rev it the voltage climbs. Any ideas? I've listed the way I've connected it below.
    GY6 CDI to Yamaha CDI
    Black connected to Black/White
    Blue connected to Green from Pulse Coil
    Green connected to White from Pulse Coil
    Yellow connected to Orange
    Red connected to Red
    Green connected to Brown
    Black connected to ( spliced into brown above)
    Yellow connected to - ????
    Blue connected to ( not connected at all )
    Blue/White connected to (not connected at all)
    Mar 2015
    Ynys Môn
    4,571
    - Hidden Content
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    742
    How much voltage does it have on it? I'm thinking your original CDI required a source of low voltage DC. The GY6 CDI does not. I would tape it off so it cannot short circuit.
    '87 TW200
    '94 Sportster 1200
    '74 XL70 Frankenbike
    '76 CT90
    '72 CT70
    '72 XL250
  1. Source of Oil Leak?
    By RobG in forum Technical Help
    Last Post: 06-20-2015, 10:00 PM
  2. basket case wiring. need wiring diagram for kickstart only.
    By mikeyrules in forum Technical Help
    Last Post: 09-09-2014, 12:18 PM
  3. Replies: 2
    Last Post: 03-31-2014, 01:49 PM
  4. Questions about stator source coil testing for 88 TDub
    By JustSomeDude in forum Technical Help
    Last Post: 03-02-2014, 08:56 PM
  5. Power source
    By Abonnette86 in forum General Discussion
    Last Post: 01-29-2013, 10:23 AM
gy6 cdi
gy6 coil
how to connect source coil
how to connect the cdi to source coil
trooubles of cdi
