Loss of top end power
Results 1 to 2 of 2
    Junior Member DesertMonkey's Avatar
    Mar 2011
    Alright here we go. Long time forum stalker, first time poster.
    I have a '91 dub with 9500 miles on it. I was out on a ride a few months ago and out of the blue my bike began sputtering, choking for life, and finally died. I started her up again and was able to run it in first and second gear to get home, though there was still sputtering, engine revving, and a little smoke. If I passed second gear the bike would die.
    All I had changed on the bike prior to this ride was I lowered the back sprocket from 54 to 50 teeth, hoping for a little more top end speed.
    I began the process of fixing or at least diagnosing:
    1. Changed the air filter (was quite dirty at this point)
    2. Changed the spark plug (looked a little lean, but not too bad)
    3. Changed the oil
    4. Ran a tank of gas with Sea Foam mixed in
    5. Cleaned out the carb (was very clean, no clogged jets. I have an in-line fuel filter so that probably helped. DID NOT adjust the float as I don't know how).
    6. Adjusted mixture screw to 2 3/4 turns to achieve slightly richer mixture
    7. Ran a compression test and got 120 (later a shop told me they read only 100???)
    8. Adjusted the valves
    Adjusting the valves seemed to help. Both valves were out of spec, intake was a little tight and exhaust was very loose. After the valve adjustment the bike will now idle fine, the engine no longer dies in higher gears, and no more smoke. I can now ride the bike in all gears, but I have a serious loss of power on the top end. Top speed with the 50 tooth sprocket is around 50 MPH and I have trouble getting the RPM's up enough to shift from fourth to fifth gear.
    I finally brought it to a shop and all they could tell me is that the "engine is tired" and I should pull apart my cylinder/piston. Or just put the 54 tooth sprocket back on as it was "making up for the tired engine".
    Does this sound like the piston to anyone? I was under the impression that the piston would affect the performance of the entire motor and no just the top end.
    Any thoughts, ideas, suggestions would be appreciated!
    (p.s. I have read TONS of threads on this forum already, but if there is a pertinent thread please send a link)
    Sounds like maybe a burned intake valve, since it was too tight.
    Anywho, try working through the troubleshooting section of the shop manual. I've switched between 15/50 and 15/54 sprocket sets and noticed no difference in top end. That is not your problem.
  1. loss of power after replacing chain & sprockets?
    By decade03 in forum Technical Help
    Last Post: 03-15-2013, 04:23 PM
  2. Would like a little more power
    By Mizzoolian in forum Performance and Customization
    Last Post: 09-13-2012, 10:32 PM
  3. I GOT THE POWER...
    By Retrofit in forum Performance and Customization
    Last Post: 08-28-2012, 02:14 PM
  4. Loss of power
    By RTCarroll84 in forum Technical Help
    Last Post: 05-11-2011, 07:06 AM
  5. No power
    By bschauffler in forum Technical Help
    Last Post: 08-27-2010, 09:07 AM
