Bleeding Brakes
Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By TW-Brian
  • 1 Post By Devils Advocate
Thread: Bleeding Brakes
    May 2013
    Groton, NY
    2,663
    Bleeding Brakes
    Scroll down to the "Take a tip from the dirtbike guys". Has anyone had any experience doing this? This is the first time I have ever seen this technique mentioned. Don't understand it but if it works, great.
    Bleeding Brakes
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Pleasanton, CA
    5,721
    The technique of zip tying the brake lever to the handgrip has worked for me on lots of different bikes.
    scotti158 likes this.
    May 2014
    Yooper, MI
    1,510
    I used to do it when I raced. I do it now after bleeding the brakes, over night a couple of nights in a row. I think it helps squeeze out some of the dissolved gasses in the break fluid and does make the brakes feel much firmer. I don't think you have to do once you've done it for a few days except I suppose more air could dissolve back into the fluid over time.
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    Bleeding Brakes
    I have been doing that for along time. I do t use a zip tie tho, I use a small quickgrip clamp
    One my Ducati the rear brake tends to boil the fluid a little (exhaust too close to the master) and hanging a weight off it every once in a while keeps me from having to bleed it constantly.
    I hand dome the same thing to cars too, I use a big heavy barbell weight leaned against the pedal. Keeps the pedal nice and firm.
  1. Air Brakes
    By LuvNot in forum General Discussion
    Last Post: 07-24-2015, 10:43 PM
  2. Bleeding Brakes
    By ZDR1 in forum Technical Help
    Last Post: 08-08-2014, 07:08 PM
  3. DIY Brake Bleeding Tip
    By thumper in forum Technical Help
    Last Post: 08-03-2014, 03:56 PM
  4. Brake fluid & bleeding .
    By frog13 in forum Off-Topic
    Last Post: 04-07-2014, 09:29 PM
  5. trouble bleeding brakes
    By dubstep in forum Technical Help
    Last Post: 06-06-2012, 05:57 AM
